Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By clutch
Thread: vh help!!
    vk 202
    Oct 2008
    Default vh help!!
    hey i guys i know this has probably been covered before but ive got a vk 202 efi with all the loom and everything ready to go etc,just seing if the smart people on here could shed some light if they have done something similar?also ive got the lsd diff,how do i go about installing that when the vh has drum brakes?
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    first u need a efi fuel tank
    vk efi,vl etc
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    vk 202
    Oct 2008
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    all else should be all sweet then bro
    should move the battery to the boot at the same time
    vk 202
    Oct 2008
    how do i go about wiring does it plug in or will i have to sort something out?the car is a manual i have an auto computer does this matter?also i have a vk dash how do i go about wiring that up?
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    the vk ecu runs the whole computer so u would have to use that, um Holden had alot of problems with manuals behing the fuel injected 202, i havnt myself done the converson, but it should be pretty simple if ur changing the dash as well
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Holden never made the EFI 202 with cogswapper so, dunno what your on about there.
    vk 202
    Oct 2008
    ive got a vk dash sitting here just wanted to know what went where,looks like an after market computer
    vkwalks39's Avatar
    vkwalks39 is offline NUCKING FUTS
    VK V8 / VH V8 / VR V8
    Sep 2007
    Stawell Vic
    Ive done it with my vh went alrite until a spun a bearing in the motor. The whole dash has to be pull out so you can run the vk dash. I use the vh heater switch cause the vk is different. U can use the diff as long u dont do to many skids. I hope this help you Cheers Jason
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by SL/ENUT View Post
    lol yeah the amount of boneheads I see saying they have a factory VK EFi 202 just makes me laugh Auto computer will work fine, do a delco conversion if your chasing power
    scott
    vk 202
    Oct 2008
    cogswapper? nah i have the lsd diff out of the calais,ive pretty much got the the whole driveline from a vk 6cyl calais,glad to hear i dont have to run an after market computer,whats the deal with the delco ecu? hard to do?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    cogswapper=manual gearbox. Slush box= Auto
    vk 202
    Oct 2008
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    It should be plug and play at the main harness near the booster, the engine computer has no connection to the auto box so a manual shouldnt be a problem. but the EFI also had a special relay controlling the fuel pump so im not sure how that comes into play.
  15. #15
    VS Calais & vh sl
    Dec 2006
    deception bay
    waste of time and effort flog it off do ecotec or buick or even 304 much much better performance.
  16. #16
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    If u isolate the EFI computer and wiring out of the VK loom, then u don't have to swap the dash over or anything. That's what I done when putting an EFI 202 into one of our VH's, it was just an extra loom that I patched in, wasn;t to hard. Chucked a manual behind that, wasn't to bad. Ya don't need to run the EST crap with the EFI dizzy either.
  17. #17
    vk 202
    Oct 2008
    cheers for all the replys guys..i want to do the rb 30 conversion as i have an wrecked vl laying around aswell,but im in Wa and probs be a pain in the ass to get registered,if anyone in wa has done it,I'm all ears!
  18. #18
    DANNY8's Avatar
    Apr 2004
    With the RB30 conversion I rekon it would be easier changing everything over. Not sure if u could rip apart the loom to make a patch loom as I'd say it's a bit more technical then the VK EFI loom.
    We bought a VK which had an RB30 in it, and yeah everything seemed to be transferred over from the VL, so would of been fairly easy, just would of been fiddley changing the entire looms over and dashboards. But doing it that way most of it will fit.
    Was a lot of fun driving it! Mainly coz it had a LSD under the bum lol.
  19. #19
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    vk 202
    Oct 2008
    the vk looks good,did it come rego'd? i just want the old vh to be good on fuel as i wanna keep it as a daily driver
  21. #21
    vn
    Nov 2009
    noble park
    est to efi conversions.
    Ive done 1 recently and sorteded out the brown shit heap i posted about a while a go so if you have any pacific questions ask them.
    unplug your exsisting engine loom at the bulkhead connector pull out the est wiring and control box put in efi loom ecu all efi related things fuel lines tank pump airflow meter.
    wire in the tachco matic relay in the fuse box as it powers up the ecu and keeps it powered up via, - signal from the coil.
    while the taco relay is made the ecu and feul pump are powered up (also the injectors and engine sensors get there supply through it).
    theres a change or 2 needed at the bulk head connector also (from memory).
