Results 1 to 24 of 24
Like Tree3Likes
  • 1 Post By DANNY8
  • 2 Post By ari666
Thread: lets talk exhausts
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    Default lets talk exhausts
    hai guise, i have a vh sle with a 253 and ive purchased some genie extractors off feebay, and i want to know what size piping to put for the exhaust, i want duel piping, im thinking maybe 2" each? engine is stock as a rock, although im thinking about a lumpy cam in the future, but that would be it.
    opinions? what would sound the best?
    also what am i expecting to pay for a duel exhaust with 1 muffler on the back?
    cheers
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I think ya should put stock cast headers back on it, keep it original.
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    mainly the reason i dont want the stock ones is because the left header has that stupid flap inside that could be jammed shut.
    VT
    Apr 2005
    QLD
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    what size are the headers? primaries & end
    see attached 3 common designs for V8s delete cats for your setup.
    Either 2" or 2 1/4" would be fine depends on what you plan to do down the track and where you want power & how loud or quiet you want it to be
    lets talk exhausts-exhaust_holden_v8_vnvs_live_axle.giflets talk exhausts-exhaust_holden_v8_sedan.giflets talk exhausts-exhaust_holden_v8_vs_irs.gif
    You will get better performance out of a X-pipe setup as it aids in balencing out the high and low pressure periods. If you look at the firing order you will see there are 2 overlapping exhaust pulses on one side, this is what creates the low pressure situations so to stop this a H or X piece is put into the exhaust to link the two banks, this will help extract the gasses out of the double fire.
    If your running a full on tuned pipe setup position can be calculated to work more efficently if your chasing every kw or ounce of torque else just make sure its infront of the first muffler or it wont work.
    It will also take a little of the crackle out of the exhaust note, make idle a little quieter and lessen the blub blub blub noise a bit but you will get power gains
    Scott
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Rather tri Ys than 4 into 1 style headers. Use those with option 3, bout 2 1/4 inch.
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    great advice guys!
    in other news, i just got off the phone to an exhaust place. and for a duel 2 inch system not inc extractors (im supplying my own) he quotes 840 ish.
    the weird thing is he says the single 2.5 inch system sounds and performs better, which he quoted me 340 supply and install.
    he said the duel 2" system with just a rear muffler will sound crap :S
    what do you guys think?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Twin into single sounds great. Although mine has single muffler. Be a bit meater duels, two mufflers then into a single.
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    id also like to note that im after it on the loud side, i expect to be over the legal limit since this isnt a daily.
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by SL/ENUT View Post
    I'm with SL/ENUT this has got a rear hotdog so it will be on the loud side but you will have drone
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by clutch View Post
    oh you mean that component of your emissions system which you need to ensure your car passes RWC?
    given up on lecturing people on how they should "leave their cars stock standard"??? no i guess not.
    +1: put the stock system back on
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    Quote Originally Posted by ari666 View Post
    cool story.
    in other news, i picked up a twin into single (joins just before the diff section i think) 2.5" system tonight. its in sections so all i have to do is weld her up! saved about 400 bucks! the system is a burkley or something. see how we go with that.
    thanks for the advice guys!
    DANNY8's Avatar
    Apr 2004
    I had a berklee box on my old VB 253....sounded like shit. Was tempting to put the old box back on that had a big ass hole in it!
    On our dirt circuit car, when we start it at night we sit the berklee box on one pipe and a lukey race box on the other (just to quieten it down for the neighbours) and the lukey sounds alot nicer then the berklee....more rumble, more quality crackle (not kicked out a muffler sort of crackle).
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I run the 3rd config on my VK with 2 1/4" into a single 3", sounds great, comes in at 96db@3000rpm, its a little on the loud side, im running the biggest hotdog we could fit at the back, if it was a daily I would try and quieten it up a bit but being drivingso rarely now im not worried.
    scott
  15. #15
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Tri Y's are the only extractors available for pre VT anyway so you are limited there.
    Single 2 1/4" is better on a 253. I agree with DANNY8, Berklee sound like crap.
    Visit my Facebook page
  16. #16
    VH SL/E, R33 GTST
    Mar 2010
    Berwick
    just the rear muffler is a berkley, so if it sounds crap ill change it over to something better
  17. #17
    VH SL/E 5.0
    Nov 2009
    I had config 1 with on my old manual VH 253, 2 1/4" into 3" with just the one Lukey centre muffler - don't know what the DB was but it was loud. It did make that sh*ty 253 sound pretty hot tho!
  18. #18
    vh sle 5lt & vx wagon
    Jan 2011
    victoria
    253s do have a deeper sounding note over the 308s. my neighbour has 253 and i have 308. both same exhaust and sat side by side his is a lot deeper note.
  19. #19
    vkwalks39's Avatar
    vkwalks39 is offline NUCKING FUTS
    VK V8 / VH V8 / VR V8
    Sep 2007
    Stawell Vic
    my old vk that i had before i got rid of it... It had genie extractors 2 1/4" straight through muffler and a turbo muffler with the tip dump. size 2 1/4" right threw. It wasn't that loud it had a nice humm at 100 km/h.
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
  20. #20
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by jcvhsle View Post
    lol. .
  21. #21
    VK Berlina/VX S Pac
    Jan 2010
    Central Coast
    I'm planning on doing my exhaust system soon when I finally get a motor, box and diff together, can I ask why (vkberlina) the pictures you showed up top show cats in the design? If its a stock 253 with no injection he wouldn't have to run them would he? Unless I'm missing something here?
  22. #22
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Just pretend the cats are straight pipes, im assuming they are from his plans for the 304.
  23. #23
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by MY_84_VK View Post
    Quote Originally Posted by vkberlina View Post
    (10 Characters)
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  24. #24
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Thats why I said "see attached 3 common designs for V8s delete cats for your setup." They are from when I was doing my injected 304 setup and looking ast different setups for my car.
    He is not required to run cats.
  1. Talk about rice!
    By MiggzvsC0MM0D0RE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2011, 12:21 PM
  2. Lets Talk Nuts
    By REWIRED in forum General
    Last Post: 09-03-2009, 07:52 PM
  3. Painting talk
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2006, 09:55 PM
  4. rocker talk
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2005, 12:39 PM
