Results 1 to 10 of 10
Thread: 6cyl and v8 brake boosters
    vr v6
    Aug 2009
    Default 6cyl and v8 brake boosters
    Hi all ,Is there any differents in diameter of a v8 brake booster compaired to a 6cyl.If so how much by?The reason i ask is that i have tall rocker covers and it is hitting the 6cyl booster.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I run a VR booster and have increased rocker cover clearances, maybe a VT one might give even better clearance
    cheers
    Scott
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    i reaallllllllllllllllllllllllllll
    lllllllllllllll
    y
    doubt that they would hit
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    not unless the motor spings backwards
    vr v6
    Aug 2009
    ? At the moment it has standard commodore engine mounts,why would you say it wouldnt hit?Is the the booster further back on the v8,s?
    ari666's Avatar
    1966 impala
    Mar 2009
    ari666's Avatar
    1966 impala
    Mar 2009
    ignore the crappy flames,
    i can get my arm in between the rocker and booster. prolly more like 2 inches that 3. you must have really tall rockers, or your engine mounts may be on the wrong sides.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Dude u MUST have it fitted wrong or something ther is a pretty big gap..
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    vr v6
    Aug 2009
    Had another look at it today and still can't find the reason why it so close.I changed the brake booster to vh 6cyl i had lying around ,it was further away but only by about 5mm.Does the arrow on the gearbox crossmember point forward or back and is vl mount brackets higher?the ones i have are 57mm.
    ari666's Avatar
    1966 impala
    Mar 2009
    i couldnt tell you, but if you put the engine mounts on the wrong sides im pretty sure itll stop the engine from dropping about 2 inches.
  1. brake boosters
    By Panama in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-12-2008, 09:35 AM
  2. V8 and 6 cyl brake boosters
    By mattw in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-09-2008, 05:58 PM
  3. Brake Boosters
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2007, 08:48 PM
  4. brake boosters
    By Calais_5sp in forum General
    Last Post: 05-02-2007, 05:53 PM
  5. V6 & V8 boosters - are they same?
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2006, 09:28 PM
