Results 1 to 15 of 15
Thread: VN V6 4 Speed Auto behind Blue 253 Vh
    VH Vacationer 202, VH SL 185 pack 253
    Feb 2010
    Victoria Pt, Queensland Australia
    Default VN V6 4 Speed Auto behind Blue 253 Vh
    Was wondering if a 4 speed auto vn v6 gear box would bolt up to a Blue 253 vh and if so is it strong enough and what is involved in hooking it up. Thanks.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Edit: Im smoking crack
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Quote Originally Posted by VK SL 3800 View Post
    No it will not fit as the bellhousing pattern is different, get one from a 304 VN or VP and itll bolt right up and is stronger.
    Nah the t700 is turbo pattern (obviously lol), and all 253's are trimatic pattern. So an adapter plate would be needed to make it fit.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Off topic, so what are 308s? Some trimatic and the later the turbo pattern. Im a little confused.
    VP Executive 5L
    Mar 2011
    You can get 308 Trimatic blocks re-drilled for turbo pattern so I can't see why you couldn't do the same with a 253.
    Also, my inability to see something is a persuasive reason for you to adopt my point of view, is it not?
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    The VN-VT 304s were all turbo patten, the older 308s had mixture of both turbo and trimatic blocks.
    Feb 2010
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    As said, get the block redrilled to suit the turbo pattern, the two middle holes and lower holes have to be done.
    Visit my Facebook page
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    ari666's Avatar
    1966 impala
    Mar 2009
    Jun 2005
    Don't need a spigot bearing with an auto Ari.....
    Although, as far as i know the spigot bearing is the same size for all Holden V8's (O/D).
    ari666's Avatar
    1966 impala
    Mar 2009
    "spigot bearing hole=10mm deep for trimatics and 15mm deep for turbo" says my book.
    it goes on to say "if you try to install a turbo transmission to a 10mm spigot hole the torque converter does not have the clearance required and will cause problems"
  15. #15
    Jun 2005
    Well, there you go, just one more reason to start with a Turbo pattern block (and a 308).
  1. [SA] FS or SWAP: Blue over silver VN 5-speed
    By VRSS in forum Vehicles For Sale
    Last Post: 12-06-2011, 01:47 PM
  2. [SA] blue VL 5 speed
    By HARVZ-6 in forum Vehicles For Sale
    Last Post: 26-10-2009, 07:37 PM
  3. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    By quick202 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-10-2005, 11:12 PM
  4. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    Last Post: 05-10-2005, 11:01 PM
