Results 1 to 10 of 10
Thread: VH SLE Odometer and Fuel low light faulty.
    L67 Calais's Avatar
    L67 Calais is offline Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    Default VH SLE Odometer and Fuel low light faulty.
    Hi,
    As the post says im have dash issues. In all honest am i better off taking it out and having a fiddle or just buying a different one for about $100 ?
    Also my fuel low light starts flickering every time i hit a bump, accelerate or turn with less than half a tank of fuel and the gauge drops to nothing with about a quarter left, SO ANNOYING!!!!
    Is the fix for this in the cluster itself or am i better off getting another tank?
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
    VH SL/E 5.0
    Nov 2009
    Odometer not working is a common problem, you can get reconditioned & recalibrated speedo's from licensed repairers, or just a used one off eBay / wreckers etc. If you have cruise control make sure the speedo you get has the cruise cable connection on the back of it (I believe this prevents the cruise operating below 60kph). Your low fuel light problem sounds like a fuel gauge sender issue (in fuel tank).
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    L67 Calais's Avatar
    Jul 2008
    Andrews Farm, SA
    Are regular commo senders the same as SLE ones? (No different wires etc)
    ari666's Avatar
    1966 impala
    Mar 2009
    yeah should be. which engine tho? you will probably need to stick to whatever engine you have i.e. carby 202, efi 6, V8 etc as there are quite a few subtle yet great differences between them.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Yeah, the stupid VK electronic dash fuel senders dont work with a normal dash to start with. A non SL/E sender may not have a sender for the low fuel light and only the gauge.
    VH SS
    May 2009
    Toowoomba, Qld
    Quote Originally Posted by MISTER VP View Post
    the senders are different, they have a low fuel switch built into the sender with an extra wire at the connector
    as far as I know only the SL/E and SS had the low fuel light senders
    L67 Calais's Avatar
    Jul 2008
    Andrews Farm, SA
    Hmmmmm, Are the senders built into the fuel tanks?
    VH SL/E 5.0
    Nov 2009
    No they are a bayonet screw type fit - see link and scroll down to ari666's embeded picture - should give you the idea.
    A couple of V8 VK questions
    VH SS
    May 2009
    Toowoomba, Qld
    as Derek said
    but they are interchangable between other VB-VH models. It's just that you won't have your low fuel light if you use a sender unit without the low fuel switch
  1. Faulty oil light ??? Check oil...
    By Daniel73 in forum VE Holden Commodore (2006 - ?)
    Last Post: 18-08-2011, 02:42 PM
  2. Faulty Fuel Gauge/fuel pump unit VU SS ute
    By paul.stewart2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-02-2010, 09:48 PM
  3. Odometer Light
    By chrism182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2009, 01:50 AM
  4. No light on odometer?
    By Branch in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2008, 06:13 AM
  5. faulty odometer....
    By peter65 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2007, 11:19 AM
