Results 1 to 6 of 6
Thread: VH V8 brake bosster on a 6 cyl
    VH SL 202
    Feb 2010
    Default VH V8 brake bosster on a 6 cyl
    im looking at changing my brake booster and i thort i put the VH V8 one in would it all bolt in? eg... bake lines i no itl bolt onto the firewall but dose the V8 ones have more lines connected up?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Its a booster......... they only ever have 1 vac line. and your front bracket wont line up and the brake lines need to be rebent slightly as the booster pushes the master foward.
    VH SL 202
    Feb 2010
    Quote Originally Posted by VK SL 3800 View Post
    okey dokie wasnt sure if there was a difference or not in them lesson learned
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Tech, doesn't matter if its a V8 or 6 banger or cringe backfire 4. Only real difference is if its a 4 disc brake booster or disc/drum one.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    AFAIK there are only two types of booster in commodores, 6cyl and 8cyl ones. It wouldnt surprise me if there are different ones for different brake combinations, i drove a HG with drums all round but had a disc/drum brake booster and it would have to be the most touchy pedal i have ever felt, absolutely shocking.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    No, there is no difference between 6 or V8 boosters, only 4 disc vs disc/drum. The 4 disc has two diaphragms while the disc/drum only has one. Thats why the 4 disc booster is a little bigger in size. Same with master cylinders, no diff, only if you have a 1 inch master one. Both my SL/Es, ones a factory 5er the other a factory 6, both have same size booster and master cylinder while dads November 1978 built VB has smaller booster and same master cylinder, factory still.
  1. alright so, brake pedal = parkers on front and rear brake light. head lights on and..
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2011, 08:29 PM
  2. brake lights not coming on until brake pedal almost to floor
    By zskinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2010, 07:11 AM
  3. Adjusting Hand Brake shoes ( disc brake )
    By Fusion in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-06-2010, 01:35 PM
  4. Some door handles & park brake & brake pads.
    By jabsy1 in forum Parts And Other Items For Sale
    Last Post: 07-08-2008, 09:53 PM
  5. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
