hey guys im doing the vn conversion ive got a full donor car with a lil front end damage and the k frame is a lil bent,can i use any from vn/vp/vr/vs as i want to use everything from the vn cheers
yes they all will fit straight in but keep the vn rack and use the vl intermediate shaft for the steering also use the vh lower arms and struts as any others are to long and will affect steering geometry.
Also as a minor brake upgrade you can use vn ss or vq statesman rotors with vs front calipers with early 1" master.
Check out my link in my sig any questions id be glad to help where i can.
Current project VH SL SEDAN 202
http://forums.justcommodores.com.au/...-83-vh-sl.html
Last project VH SL WAGON L67
http://forums.justcommodores.com.au/...h-wagooon.html
cheers mate,i wanted to keep the vn suspension and springs as its new,so if i get a vr k frame i cant use the vn struts?vh lower arms is ok as i still have it all
Yes you can use the VR K frame with the VN struts and VH lower arms. You cannot ust the VR lower arms and struts in you VH.
Forgot vn use the same top so yeah vbred is spot on.
cheers guys i got a nolathane evocom1 front bush kit from vb - vp, can i still use this gear if i get the vr k frame? cant seem to find a vn-vp one
i dont see why not just check the strut bar to chassis bush part numbers.
just opend the pack it all fits and i just scored a vn k frame for 50 bucks cheers for the help lads
