Results 1 to 3 of 3
Thread: vk ecotec wont start
    holden vs
    Mar 2010
    Default vk ecotec wont start
    hey iv just pop a vs ecotec and 5 speed into my vk wagon iv brought a Memcal with the vats trun off etc now iv got spark and fuel but wont start. thinking injeters? or is there something i could be missing in my wireing for them not to be working?
    Built with Spanners. Not chops sticks
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Mate there is a million things that you could have done wrong and because its modified its hard to help you, check for an injector pulse, and that you have the CEL on while cranking and with the ignition on, the CEL is a good quick way way to see if the ECU is happy with everything but its not a fool proof method.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by VK SL 3800 View Post
    I'd go with the code check as well
    Checking error codes VR/VS (Revised)
    Obviously your computer plug will probably be some where else but at least it gives you the codes.
  1. vs calais wont start unless i kit unlock before i start
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:40 PM
  2. VYII Berlina ECOtec wont start - suspect fuel issue.
    By Slave to the VYII in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-08-2010, 10:58 AM
  3. VZ ute ecotec wont start?
    By stevo1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-07-2010, 11:37 PM
  4. VP V8 Wont Start
    By E_ri_k in forum Electrical Wiring / Questions
    Last Post: 04-03-2009, 03:57 PM
  5. vn wont start
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2009, 06:56 PM
