Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: HIDs in the old girls
    VH SL 202
    Feb 2010
    Default HIDs in the old girls
    just wondering if anyone has tryed HIDs in the old cars i was thinking of putting some HIDs in but not sure might just mount some lights behind the grill
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    You'll probably end up melting the lenses. Plus make the car look shit.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    VH SL 202
    Feb 2010
    Quote Originally Posted by SabbathSS View Post
    the HIDs run like 2x cooler than the halogens not sure if it would look crap i just want more light from these headlights
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Also highly illegal.
    HJ premier
    Jun 2010
    old girls have glass lenses i highly doubt they'd melt.
    VH SL 202
    Feb 2010
    Sabbath''s Avatar
    Jul 2006
    Quote Originally Posted by 75hjprem View Post
    Meant the reflectors behind, not the lens. Doh
    Sabbath''s Avatar
    Jul 2006
    Quote Originally Posted by TY318 View Post
    y r they illegal
    Dont comply with ADR's
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    i'd try with a new set of headlights first. when i had ym vl it made a fairly big differance, i guess it just depends on how bad your headlights are faded/oxidzed.
    VH SL 202
    Feb 2010
    VS Calais & vh sl
    Dec 2006
    deception bay
    with the design of the early headlight i reckon the beam would be allover the place and blind on coming traffic.
    New headlights and blnkers cost me $90 and with good quality globes perform quiet well just make sure you adjust them properly.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    y r they illegal
    cos' lights get vigorously tested to make sure they are not too bright and able to be aimed correctly.
    HID's also (as rick mentioned) have a nasty habbit of melting things, and the entire case of standard headlights is made of plastic, so i would guess that would be the first to go.
    you would have to rewire your lights to run HID's anyway, cos' they need a feed directly from the battery + and - so why not just rewire your existing lights with a relay for each one. if i remember correctly, you have already pulled your lights apart and thoroughly cleaned inside, so i think you will be surprised at how good a direct + supply will make them.
    then once you have a good power supply, you can try higher wattage H4's.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Bahaha run hotter oh jeeze. So much misinformation in this thread. As said pick up some new headlights if you can then run some decent globes. Will make a world of difference.
    VH SL/E 5.0
    Nov 2009
    I got an original good used pair of headlight assembly's from a wrecker and put 100/80w H4's in my previous VH, cleaned up the connections and made sure the wiring was sound. The headlights turned out great, nice and bright. If you do 100/80w H4's though you will need to put in a relay so you don't burn out the switch.
    I was recommended some type of phillips globes recently by an auto elec where they produce a very white and bright beam of light but draw much less power than the standard H4's - I put them in the SL/E and was very impressed. I can't remember the name right now but if I get a chance over the weekend I will try and dig out the box they came in and let you know.
  15. #15
    L67 Calais's Avatar
    L67 Calais is offline Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    Name & Type Please!!!
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
  16. #16
    VH SL 202
    Feb 2010
    Thanks guys for the info I might just do as derekp said run higher wattage bulbs
  17. #17
    VH SL/E 5.0
    Nov 2009
  18. #18
    ari666's Avatar
    1966 impala
    Mar 2009
    once again, i dont think you listened. to run higher wattage bulbs you will need to run relays, or itll put too much strain on your switch and wiring.
  19. #19
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Don't run a higher wattage bulb it's not as easy as oh wire in a relay away you go. There's more current drain on the wire for a start = heat = potential fire = oh shi. Better off getting some Phillips Xtreme Vision +80's. Nice crisp white light.
  20. #20
    ari666's Avatar
    1966 impala
    Mar 2009
    lol, what are you on today? :P
    battery constant to relay, relay to globe. heavier duty wire than stock, then your existing HL + supply becomes an on/off switch.
    ???? how hard is that? and no, there wont be any fires.
  21. #21
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    You said rewire you didn't say upgrade so I misread your post.
  22. #22
    VH SL 202
    Feb 2010
    i did listen i was on my phone i couldn't be f##ked typing it all
  23. #23
    VH SS
    May 2009
    Toowoomba, Qld
    the headlights in the early girls were actually very good when the cars were new 30 years ago. But unfortunately Holden was tight arsed and didn't fit relays to the headlight circuit like later models. So as the wiring and switches got some age on them, resistance increased, less power to the headlights hence dull headlights.
    simply fitting relays & retaining standard wattage light bulbs makes a HUGE difference.
    So first thing I'd do as Ari suggested, is fit relays. If you fit high wattage headlight bulbs to the existing setup, it's just going to end up melting wires
  24. #24
    L67 Calais's Avatar
    Jul 2008
    Andrews Farm, SA
    Can someone post a link to these "relays" you keep referring to? - Will be doing this VERY soon!
  25. #25
    ari666's Avatar
    1966 impala
    Mar 2009
    gereric 4 post relay:
    available from pretty much anywhere. service stations, supercheap auto, repco, burson etc etc.
    not tricky to wire up, i just havnt got time to make a circuit diagram right now.
  1. Good Girls and Bad Girls
    By BlackVXGTS in forum Jokes/Humour
    Last Post: 06-05-2011, 12:07 PM
  2. HIDS in a VT
    By jamex101 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-08-2010, 01:10 AM
  3. Help with HIDS
    By trentvy in forum Electrical Wiring / Questions
    Last Post: 13-01-2010, 04:15 PM
  4. HIDs for me Ute?!?!?
    By Cheech in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2008, 02:10 PM
  5. HIDs on VE?
    By NoStopN in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-02-2007, 01:27 PM
