Results 1 to 9 of 9
Thread: 202 Leaking Exhaust Gasket help
    VU S2 Manual
    Sep 2009
    Default 202 Leaking Exhaust Gasket help
    I have a red 202 in my vb, and there is a leak at the exhaust manifold. The previous owner squeezed 2 gaskets in to seal a earlier leak but now after replacing the old gaskets with one new one there is still a leak at the back. Would it be possible the headers have warped and now won't seal properly? What could I do/use to seal the leak?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Being a red motor it probably still has a stud right at the back instead of a bolt, you could try and pull the stud out and put in a bolt so there is some clamping force which might help. Your probably right and your headers may have warped, if they leak right after replacing the gasket they need to be machined.
    VX SS
    Jul 2005
    East of Melbourne
    I had to pull the extractors off our Blue 202 a while back to fit a new starter motor, I bought a new exhaust manifold gasket from the local exhaust place and he suggested I should use some high temp exhaust silicon on either side of the new gasket, I bought a tube a sort of a red coloured stuff and smeared it on both sides,
    was a bit messy, but it has sealed up beutifully not a sign of leak anywhere, maybe some of that stuff on the gasket might help.
    VH SL 202
    Feb 2010
    Quote Originally Posted by Drewie View Post
    u shouldnt have needed to pull the headers off i got my startor motor in and out with the headers on it was a f**king c**t tight space but i got it
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I suggest you pull the manifold & headers off the engine and put a straight endge to them and see whats actually warped, replace as required. Prior to fitting parts back ontot he head clean it up with a scotchbrite and wax & grease remover and make sure no grease or oil are present, the gaskets are usually fibre/alloy composite gasket or complete alloy which will mould to the surfaces under pressure & heat. Correctly torque the manifolds, so you get the manifolds to seat correctly esp if you have had problems tighten up firm just past finger tight, give a wiggle of the manifolds and slowly torque up in 5nm increments. Check the manufacturers requirements on the gaskets to give a better seal it may be recommended to heat up to opperating temp then to let cool and retorque studs and bolts.
    scott
    VHSLE/VXSS/VXEXEC
    May 2011
    like he said ^...
    the good thing about getting older....more toysthe bad news more headaches
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    take em' off.
    layer on 4mm of rtv high temp silicone
    wait 24 hours
    layer on another 4mm
    fit headers
    wait 3 hours
    drive you new 'exhaust leak free' car
    profit
    VX SS
    Jul 2005
    East of Melbourne
    Quote Originally Posted by TY318 View Post
    What ever brand of extractors that are on our VC they run extremely close to the original big bodied starter, I undid the starter and there was next to no movement, lucky to have been 1 cm, as soon as you tried to move the starter back it hit the extractors there was no way it would have come out with the extractors on, maybe some brands have a little more clearance than others. The new starter is a lot smaller and looks like it would slip out quite easily if needed. But going back to the original question the new gasket and the high temp exhaust silicon sealed ours up beutifully, I checked the bolts a few days later and nipped them up again as well.
    commodore vk auto 3.3 everyday car
    Oct 2009
    Quote Originally Posted by bozza91 View Post
    On my engine the alloy surface of the inlet manifold where the square washers go were worn/crushed right down and any tightening down of the nuts just didn't work therefore creating a air/vacuum leak.
  1. v8 head gasket leaking??
    By admir87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2011, 10:22 AM
  2. Oil still leaking even after rocker cover gasket changed...
    By Kierab in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2010, 08:53 PM
  3. Flange Gasket and Exhaust Manifold Gasket
    By mrvdv85 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-09-2009, 06:46 PM
  4. vs clubsport dizzy gasket leaking
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-07-2009, 09:22 PM
  5. oil leaking from tappet gasket...
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 10:33 AM
