Results 1 to 6 of 6
Thread: LO FUEL light on sle dash cluster
    VH SL 202
    Feb 2010
    Default LO FUEL light on sle dash cluster
    hey guys
    just wanna know how would i go about hooking up the *lo fuel* light on the vh sle cluster?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    you need an sle fuel sender unit in the tank and then need to wire it in as im pretty sure ony the SL/E wiring loom has a wire for it.
    L67 Calais's Avatar
    L67 Calais is offline Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    sounds like a pain in the ass! im doing the opposite and disconnecting mine!!
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    dick smith used to sell a kit i think that was a comparitor type of circuit that you could adjust via a variable resistor to trigger when you wanted it to that followed the resistance of the gauge sender unit so it would work using your stock sender....but thats more expense if you could find it on the net.
    I remember seeing a sender unit for a vh with a trip computer a while ago and it had a simple switch mounted on the gauge unit inside the tank that made when the float got to a certain level and the arm touched it but it also had another add on bit like a relay mounted behind the gauge cluster that when the light was triggered by the switch in the tank ,it kept the light on so it didnt turn on and off as the level changed when the fuel moved around in the tank.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    EDIT: nvm no it doesn't
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VH SL 202
    Feb 2010
    dose neone know if a sle trip computer plus a loom for em would plug straight into a sl model mines just the basic model lol
  1. Stage 2 Dash Cluster/ Shift Light
    By Dazza07 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2008, 11:50 AM
  2. fuel warning dash light
    By JT090 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2008, 12:15 PM
  3. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  4. VH SLE Cluster fuel low light
    By johnmic in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-02-2007, 09:06 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
