Results 1 to 8 of 8
Like Tree2Likes
  • 2 Post By ari666
Thread: Vn stroker questions
    VB SLE
    Apr 2009
    Default Vn stroker questions
    GDAY GUYS. I'VE BEEN TOYING WITH THE IDEA OF GOING WITH A STROKER KIT OR REBUILDING THE 308 STANDARD STROKE. I'VE HAD A COUPLE OF QUOTES FOR THE STROKER BUT I STILL HAVE QUESTIONS. DOES THE BLOCK NEED MACHINING AT THE BOTTOM END? ARE THE KITS ON EBAY TRUSTWORTHY ? WHO'S USED WHO IN MELBOURNE AND WHAT EXPERIENCE DID YOU HAVE? I'VE BEEN TO FLOWCRAFT ,MSC PERFORMANCE AS WELL AS ALLSPARKS, THEY ALL SEEM TO KNOW THEIR STUFF AND IVE SEEN EXAMPLES OF ALL OF THE CARS THEY HAVE WORKED ON. ALL LOOKED AND SOUNDED GREAT. MY MOTOR IS IN A VB SLE WITH A T700 AND VLT LSD WITH 3.77'S. I KNOW A STALLY WILL ALSO BE NEEDED. ANY HELP WOULD BE GREATLY APPRECIATED. STEVE
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    Steve
    I picked up a calais. I am going to put a Pavtek Stroker in it with EFI. I will need to pick you brains as to how you did the electricals on yours.
    Pete
    VB SLE
    Apr 2009
    Default Vn to vb transplant
    Pete, mine is out of a vn so i hope this helps. We unbolted the complete k frame and put it into my vb. The wiring harness was intact so we drilled hole into the firewall and mounted the computer in the passenger footwell. Forgot to mention that the trans was put in at the same time although a new crossmember had to ordered from Castlemaine rod shop as well an accelerator cable. The battery was relocated to the boot as the pod goes into the area where my battery was. The fuel tank was replaced with a vn 90lt drop tank as I like them but more importantly it needed a tank with an internal pump. All the electrical was finally wired by a sparky to be on the safe side and i've been happily motoring like this for about two years. Steve
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Maybe try in here-
    V8 Development and Modification
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Jul 2009
    Melbourne - SE
    Just been looking on the V6 Conversions site. They do a loom to interface between the EFI Engine and VK. Problem solved. Now all I need is a big bucket of cash to get started.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Quote Originally Posted by VBRED View Post
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    Jul 2009
    Melbourne - SE
    Thanks Mate.
  1. VT 355 Stroker Questions PLEASE HELP!!!
    By comfreak in forum V8 Development and Modification
    Last Post: 04-01-2011, 12:20 AM
  2. 355 stroker build questions
    By brewerboy in forum V8 Development and Modification
    Last Post: 08-06-2009, 11:05 PM
  3. 304 383 Stroker Kit from Pavtek Performance Questions.
    By pedrotski in forum V8 Development and Modification
    Last Post: 19-04-2009, 08:10 PM
  4. 355 stroker
    By Heeey!! in forum V8 Development and Modification
    Last Post: 02-04-2009, 03:02 PM
