Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Pub247
Thread: lifter change in 202 couple of questions
    commodore
    Aug 2009
    australia
    Default lifter change in 202 couple of questions
    my engine is getting a little tappy on idle (only a very little tapping) but enough to annoy me im thinking its the lifters or a bent pushrod my questions are, can i replace the lifters without having to replace my cam as im happy with the cam i have in it goes well with the cam i have and ive been looking at crane hardened pushrods on ebay do they come in different lengths or is it one size fits all, probably a stupid question but if i dont ask i wont know.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Pushrods do come in different length but as long as you get the right ones to suit your motor you'll be right.
    As for lifters yes you can do them without removing cam but i'll warn you now its not the easiest of jobs if shit goes pear shaped. Number 1 issue is when they mushroom the bottom of the lifter where it makes contact with cam. This makes it really difficult to get them out through the lifter bore.
    My old VH when i did them i ended having to knock them into the sump which is not ideal as then you got to get them out of the sump
    Not saying this has happened to yours but be prepared sometimes its not as easy as
    Remove rocker cover
    Unbolts rockers (keeping in order removed)
    Removing pushrod
    Unbolting Side Plates
    and pulling out lifters (turning motor to get them up)
    So plan ahead and leave yourself plenty of time to complete it not i need this going again in 2 hours type of scenario
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    commodore
    Aug 2009
    australia
    thanks pub ill keep all that in mind when im changing them ,is it worth throwing on a new headgasket whilst its mostly apart anyway as ive done headgaskets etc but just never had to change lifters.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    I had realllly noisy lifters mate, I changed oils and it completely stopped lol
    Just a idea before u pull shit apart
    Penrite hpr30
    VX series 2 SS 6 speed,VK Royale 308,VN V6 Ute
    Mar 2009
    Coromandel, NZ
    No point doing head gasket,thats a whole lot more work for nothing..And jonnoos right sometimes it can be as simple as bad oil
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Choose an oil with an API-SL rating as some newer oils (API-SM & API-SN) dont contain a vital anit-scuffing agent for flat tappets like in all older Holden engines can cause cam follower or camshaft failure, not common but it can happen.
  1. Couple Questions
    By Sik_Cordz in forum V8 Development and Modification
    Last Post: 26-01-2011, 05:50 PM
  2. VS couple of questions.
    By Brett_jjj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2010, 11:28 AM
  3. couple of 304 questions
    By pow3rslave in forum General
    Last Post: 20-06-2009, 02:44 PM
  4. a couple of vs ute questions
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2008, 08:22 PM
  5. couple of vl questions.
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-01-2007, 06:40 PM
