Does anyone have any photos or diagrams of a V8 pedal box to see the difference between the 6 and 8.
Is it possible to modify a 6 to work ok in a V8?
Pete
Yeh I did a search and I found this.
And I found this. It does not look like an easy job to modify a 6 then.
I have been looking at the difference between the 6 and V8 pedal box. The pivot position is relocated therefore if the 6 or the 8 had the same clutch clamping pressure then additional foot pressure is needed for the V8 pedal. It is obvious that the reposition is to allow for increased travel. I am thinking that if the clutch fork was shortened the proporional amount from the pivot point to the point of attachment of the cable on the pedal then the same result will be achieved and easier to modify. The hole that retains the cable at the gearbox end would need to be repositioned or angled.
VBRED, V8 Clutch pedal like 30mm long where the cable hooks on too..You can use a 6 Cylinder one but pressing on it will be hard..I Hope this helps mate..Cheers j
MISSING
WIFE AND DOG
REWARD FOR DOG!!
Ive got a 6 cylinder one in mine and it works fine.Clutch isnt even heavy
Kane, i just heard that they are, cool!! I'll be putting a V8 with a aussie 4spd in the vh, and using a 6 cylinder pedals. thx for that. Sorry vbred for stealing your thread mate, I'll leave you alone....COOL VK by the way!!!
MISSING
WIFE AND DOG
REWARD FOR DOG!!
VBRED the pedal is a little higher but you dont really notice it when your driving.It selects all gears fine.Yea im running a T5 and before that i had a celica box, no issues there either
Dellow do a change over with a 6 banger auto and makes a proper V8 manual pedal box
Yeah I would get the Dellow one. They are impossible to get at the wreckers.
Dellow have clutch forks and clips and all that as well.
This is on my list of 'things to get' for when I do the V8 conversion on my Commodore L
