Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By drewVHSS
Thread: What brake boosters fit a VK?
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    Default What brake boosters fit a VK?
    I've done a bit of a search but couldn't find a definitive answer?
    What brake boosters will fit a VK commodore? (with an EFI 6 if it matters)
    I've got one off a VR and the body of it is about an inch deeper than the VK one.
    ECOTEC KICKED IN yO!!!!!!
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Anything up to VS commodore is a direct swap, VT and later require modification.
    May 2004
    darwin
    How does that work if the one that I pulled out of a VR is a different size? The master cylinder will end up being about an inch forward in the engine bay and I'll have to modify the bracket for it.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    The firewall side is the same, so bolts directly to the firewall and pedal, just make up a new front bracket or get one off a V8 commodore.
    May 2004
    darwin
    Ah, cool. Thanks for that. I might be able to get away with just drilling new holes in the bracket.
    May 2004
    darwin
    I forced it in there. The master cylinder is just touching the bolts for the bracket, I'll take to the bolt with the angle grinder and give it a bit of space.
    May 2004
    darwin
    Cutting about 5mm off the bolt seems to have made it fit. Now to get some petrol and see if it has fixed the lack of brakes problem.
    May 2004
    darwin
    Hrmmm, it appears that it isn't working properly. Someone has suggested that the plungers might be different lengths.
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    There's a forum i read ages ago somewhere about using newer model boosters and master cylinders on early commodores.
    From memory here's basically what the popular mod to do is:
    Use a VS plastic booster (bolts to firewall same as early but is bigger diameter and may not clear rocker covers if you have an early v8, will fit vn headed rockers if you have the vn top end)
    you need to cut down the push rod 5mm into master cylinder.
    Master cylinder's that fit VS booster is VS and VT types only. You want the VT 1-1/4" large bore quick fill master cylinder (this combo is a must for using big brakes on early commodore, without this mod you wont have the pedal feel or master cylinder strength to operate big calipers)
    Pedal rod needs to be cut down and a new locating pin hole drilled.
    I can't remember the measurements off hand but it's something you can do by dummy fitting and measuring anyhow.
    $60 gets you 3 brass fittings to fit your brake lines to the new master cylinder (vs vt use different pipe flare to early vb-vl)
    Back to the VR booster you're using, I'm pretty sure you still have to trim down the pushrod into the master cylinder and also shorten the pedal rod same as using VS booster.
    On one hand with the VR booster you can use your old 1" master (not much of an improvement of braking performance or pedal feel)
    On the other, if you use VS booster which will fit the VT master cylinder you'll need to spend more to get it all done but it'll be worth it as it paves the way to handle big brakes later down the track.
    You can use a vt booster but you'll need to make your own bracket to fit it to the firewall and still shorten your pedal rod.
    I'll keep hunting to try and find the original thread i learn't all this from
    May 2004
    darwin
    Thanks for that drew. It's just a six so clearance isn't a problem. Also, it's a 15/16" master.
    I'll have to measure it all a bit more accurately.
    Lewie's Avatar
    Lewie is offline B Cast and flat topped!
    Very thirsty VT & VH project under way! YAY!!
    Nov 2006
    Nowra, NSW
    I did this conversion a while ago. Could be some info in here useful for you.
    VH Brake Upgrade
    Check out post #21
    "Please contact the Administrator if your date of birth has changed." JC Forum. Profile editor.
  1. 6cyl and v8 brake boosters
    By Guzzoline addict in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2011, 09:01 AM
  2. brake boosters
    By Panama in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-12-2008, 09:35 AM
  3. V8 and 6 cyl brake boosters
    By mattw in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-09-2008, 05:58 PM
  4. Brake Boosters
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2007, 08:48 PM
  5. brake boosters
    By Calais_5sp in forum General
    Last Post: 05-02-2007, 05:53 PM
