Results 1 to 5 of 5
Thread: footwell lights
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    Default footwell lights
    Hi there, I want to put foot well lights in the front of my VH. How would I go about wiring it up so they come on wen interior lights are on. Do I need relays or anything to stop voltage drop. Any help would b great.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    take the passenger side kick panel off and you will see some white wires floating around in there somewhere that connects to your door switch. those wires are earth. find an + constant from somewhere, then bridge the - to the door switch wire, and hey presto you have working footwell lights
    you might wanna be careful how many/what type of lights you are installing. the door switch isnt rated that highly Amp wise, so running a shitload of 5W bulbs could burn out the switch.
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Quote Originally Posted by ari666 View Post
    You'd be able to bypass that worry of switches blowing by adding a relay, yeah?
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    ari666's Avatar
    1966 impala
    Mar 2009
    yeah. use the earth as the realy trigger and bridge your constant + over pins 30 and 85
  1. footwell lights
    By v8vlwags in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-09-2011, 09:01 PM
  2. Berlina footwell lights
    By sweefu in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-07-2010, 09:45 AM
  3. VS Footwell Lights.
    By tim005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2010, 09:40 PM
  4. LED Footwell Lights
    By PaulSV6 in forum ASR Audio & Electronics
    Last Post: 17-03-2010, 10:22 PM
  5. Stock footwell lights?
    By dynamik in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-01-2010, 05:25 PM
