Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Pub247
Thread: compression checking
    1979 Commodore 3.3 sedan, 2001 VX Commodore Equipe
    Aug 2009
    Orange NSW
    Default compression checking
    Hello all,
    As mentioned in another thread the VB got its compression checked today. It got between 120-125psi. I understand that that this does not line up with the specifications i.e. is a bit low. However, the car runs fine, blows no smoke, uses no oil.
    I live at a highish altitude (870m) and today was very cold (7 degrees) - could this affect the outcome significantly?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    just an old tired motor ie its a bit worn out a good freasj motor would be 150-160 so yours isnt bad main thing is they are all around the same comp which means there nothing major wrong
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Aug 2009
    Orange NSW
    Well, I checked it myself, as per the gregorys manual directions, and it got 136-143, using a brand new screw-in type gauge that cost $24. Seems the mechanic forgot to pull the choke out or something......or my gauge is faulty...i'll go with the former Sleep sounder now
  1. checking tps
    By richardpalinkas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2010, 10:02 PM
  2. Just Checking.....
    By mrhotdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2009, 06:31 PM
  3. just checking....
    By Ripcell in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2008, 08:14 PM
  4. Checking Front End.
    By Onecontrolfreak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2006, 01:39 AM
  5. ECU Fault Checking How?
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-09-2005, 10:03 PM
