Results 1 to 4 of 4
Like Tree5Likes
  • 2 Post By VK SL 3800
  • 3 Post By ari666
Thread: Help needed for gauge installation into VB
    VB Commodore
    Jul 2011
    Default Help needed for gauge installation into VB
    Hi all,
    I've got a VB and i'm building a black 202 to put in it. I want to put Autometer Oil Pressure and Water Temperature gauges in it but i'm not quite sure how to wire them up. i know how to wire up the positive and negative wires but I dont know exactly how to wire them up to the motor to get the readings.
    Any help is much appreciated.
    Thanks heeps
    James
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    I dont know how you intend to build an engine if you dont know how to connect up those two sensors, temp sender is at the back of the head drivers side, oil pressure sender is on the block near the oil pump and filter.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by VK SL 3800 View Post
    wires are scarry.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    From memory look for a blue wire for your oil pressure and light green for temp.
    Have a look at at my site I should have diagrams up there.
    Wires Blah!! thats not scary check out the attached pics of my rewiring my VK & wiring up my EFI 5L
    Scott
  1. gauge installation
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2010, 01:24 PM
  2. VZ SV8 Gauge Pod Installation
    By macca_223 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-12-2008, 08:19 AM
  3. Mechanical Temp Gauge Installation
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2006, 02:22 PM
  4. URGENT,important installation help needed
    By ProMaX in forum Car Audio
    Last Post: 01-02-2006, 08:15 PM
  5. Replies: 6
    Last Post: 15-06-2004, 06:30 PM
Tags for this Thread
