Results 1 to 6 of 6
Thread: V6 convertion tail shaft question.
    Project VK
    May 2011
    Port Lincoln, SA
    Default V6 convertion tail shaft question.
    hey guys, starting to get through the V6 convertion slowly as im in my seniour year of high school i can only work weekends which limits my money flow which makes it hard to get things done but just wanted to ask, i have a T5 and a VN *WAGON* LSD going into my VK sedan next week and i was just wondering what tailshaft options i have, is it possible to use the wagon tailshaft on my VK sedan? any help would be great.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    AFAIK a wagon front half is the same as a sedan, you will need to source yourself a Vl rear section if you have late model Vk with a borgwarner diff or a VB-VK V8 rear section if it has a holden made Salisbury diff.
    also your wagon diff wont go into a sedan.
    Project VK
    May 2011
    Port Lincoln, SA
    Its a 1985 model, it has a borgwarner diff, and yes im aware that the it makes the track wider and that the strut mounts on the wagon diff are on a angle not straight up and down, the girlfreinds dad is a frabricator. Hes going to cut off the wagon mounts and fit VN sedan diff mounts in there place, is there any other problems i may run into? Thanks for the help.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Project VK
    May 2011
    Port Lincoln, SA
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    I suspect you will have to roll the guards to get them to fit.
  1. V6 convertion tail shaft question.
    By Shaun_VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-07-2011, 09:28 PM
  2. tail shaft
    By tenggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2009, 02:44 PM
  3. tail shaft
    By Disturbed_vegeta in forum V8 Development and Modification
    Last Post: 13-09-2008, 07:18 PM
  4. tail shaft IRS
    By LOWPSI in forum General Discussion
    Last Post: 15-05-2008, 09:26 PM
  5. Tail shaft
    By Idenity Crisis in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2007, 09:41 PM
