Would any one know if u can use a efi altinator in the carby engine?
Cheers my85vk
yeah. only difference is you need to figure out how to switch it on and change the pulley from a serpentine to a V-belt
What do u mean by switch it on?? Cheers
Use an old injector wiring plug to hook onto the regulator.
S wire can loop straight back to the B+ terminal (S is sense wire)
I wire is the usual Indicator wire to goto the dash.
Rattle gun should get your pulley off if you need to change it.
VN v8 alternator shoud be normal V belt
VT S1 5.0L alternator will be serpitine belt.
Cheers mate
