Hi, can som1 shed some light on how 2 remove the doors. I think I can get the door pins out but have trouble. Also the pin for the check stap is pissin me off. It won't budge. Theres no rust on them. Can ya help me!!!!!!!!!
Have you tried soaking in WD40 or similar a couple times?
door check strap, have to drill it out. As said, soak the door pins in CRC, WD-40, any release spray/liquid.
there is a tool available for removing door pins, makes it real easy
Door Hinge Pin Remover Extractor Tool Commodore | eBay
We use a slide hammer on the door hinge pins they come out really easy.
As for the check strap pins mine have a one way pin that you hit down to fit and hit up to remove.
Scott
Cheers. Got them out afta soaking them in CRC and had to drill the check strap pins out like u said sle/nut. Thanks people.
