Results 1 to 7 of 7
Thread: diff conversion
    VB Commodore
    Jul 2011
    Default diff conversion
    i just bought myself a vk diff with disk brakes to put into my vb. Its just a standard non lsd diff but i just wanted to make sure there was nothing i needed to change. I was told something about having to change the brake master cylinder because of the disks. could someone please clarify.
    Also the diff is complete minus a handbrake cable, could i use the stock handbrake cable from my diff or not?
    James
    holden vs
    Mar 2010
    yes master cylinder will need changing i have a disc diff in my wagon but havent change master cylinder yet (as car is still a project in the shed not on road) and yea car dosnt stop very well lol as for hand brake cable i thank they are different but i havent got there yet lol
    Built with Spanners. Not chops sticks
    VC
    Oct 2008
    Handbrake cables are different and you need to replace the 15/16" master cylinder with a 1" unit.
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    Some later VKs ran the Borg Warner diff. You may have to change the rear half of the drive shaft as well. If your car had drums then you will need to change the handbrake cable.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by NPreston View Post
    i have heard a lot of people saying that, which is weird cos' my V8 VK which is an L32 so factory V8 is running a 15/16's master (from factory) and obviously it has 4 wheel disc brakes.
    so yeah, master cylinder change is unnecessary. mine works fine.
    VC
    Oct 2008
    Quote Originally Posted by ari666 View Post
    Forgot I also upgraded to VT brakes, that's why I changed master cylinder.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    There is two types of 15/16 master the drum and disc style, my factory 308 also has the 15/16 with discs, drum masters have a residual pressure valve and a biased a bit differently as drums require fark all pressure to work compared to discs.
  1. need help!! 9 inch diff conversion
    By norman89 in forum V8 Development and Modification
    Last Post: 14-08-2010, 12:50 PM
  2. VL LSD diff conversion
    By 05 Senator in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-07-2010, 03:17 PM
  3. diff conversion
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2008, 02:04 PM
  4. vr to vb diff conversion
    By oldenvb in forum General Discussion
    Last Post: 09-05-2006, 02:57 AM
  5. VLT diff or disc conversion
    By Snowfox in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-10-2004, 06:16 PM
