Results 1 to 5 of 5
Thread: Help Needed - Rebuild red 202
    NA
    Aug 2011
    Brisbane Southside
    Default Help Needed - Rebuild red 202
    Hi all,
    I'm looking for someone who is able to rebuild a red 202. The car is in Logan area, Brisbane. Can work on it in the carport here, or I can drive it to you locally (it won't get very far in it's current state :P).
    A decent amount of cash is on offer to someone who can get this old girl up and running and purring again. Interested? Or know someone who is? Get in touch
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Much much much cheaper to find a good second hand one if possible, then you can buy a engine crane and put it in yourself with the money saved.
    VH Vacationer 202, VH SL 185 pack 253
    Feb 2010
    Victoria Pt, Queensland Australia
    I have a Blue 202 here and bought it for the gearbox.Have never heard it running but was told it was in good nick. Came out of a VC.I am at Victoria Pt. 4165.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Is it a matching numbers car?
    If not it would probably be cheaper to buy a second hand motor or even better if your not in a rush the Holden straight six is a great place to cut your teeth on a rebuild (nice a simple engine).
    VS Berlina
    Mar 2011
    Woodford QLD
    Yep fix it yourself. Red six has to be about the simplest motor ever built. Great way to learn about engines. Play with it, mod it, learn. In the meantime, stick a cheap secondhand one in. They are cheap and expendable.
  1. [308] rebuild what is needed
    By vk5ltr in forum V8 Development and Modification
    Last Post: 18-03-2010, 10:54 PM
  2. vt ls1 ss 5.7l help needed rebuild/buy new engine/box
    By ls1jet in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-06-2009, 10:12 PM
  3. Opinions on which V6 to rebuild needed :)
    By shmickmik in forum V6 Development And Modification
    Last Post: 12-12-2008, 07:51 PM
  4. To rebuild or not to rebuild!? advice needed
    By Jason1987 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-08-2005, 08:36 PM
  5. V8 Rebuild and mod advice needed
    By Daters in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2005, 09:09 PM
Tags for this Thread
