Results 1 to 4 of 4
Thread: Fuel flow sensor
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    Default Fuel flow sensor
    Hi thr, does any1 know if the fuel flow sensor that bolts onto the engine on a VK 6 is the same as the one on a VH 6??????? And r the fuel flow sensors the same on a 6cyl and a 8cyl.
    Zac
    Zac is offline
    VK Calais V8
    Dec 2004
    Yes, it will physically fit, 'cause the carbs are the same (for the 3.3 litre EST engine), but the trip computer on VKs was part of the Calais electronic dash. VK Calais were fitted with the 3.3litre EFI 6 cylinder, so the fuel measurement was taken from the injector pulses - there was no flow meter in the fuel line.
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    Thanks Zac. So if i get a VK fuel flow sensor and bolt it to my motor, run the VH fuel lines to the carb and connect it to my engine harness, it should work? I bought a VH sle and the fuel flow sensor was taken off but the whole trip comp is still in the car.
    Zac
    Zac is offline
    VK Calais V8
    Dec 2004
    Yep, spot on! That's the beauty of Holden - just 'cause they made a new model didn't mean they changed every single component.
  1. VH SL/E Fuel Flow Sensor
    By svs500 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-05-2010, 09:49 AM
  2. [ACT] WTB: VH SL/E Fuel Flow Sensor
    By YMY-88U in forum Swap / Wanted to Buy / Trade
    Last Post: 19-05-2009, 08:37 PM
  3. Manifold Air Flow Sensor
    By Jon Z in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 04:31 PM
  4. air flow sensor fault
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2007, 08:37 PM
  5. WTB: VS V6 Air Flow Meter Sensor
    By Lord-Data in forum Swap / Wanted to Buy / Trade
    Last Post: 23-02-2005, 06:12 PM
