Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By VK SL 3800
Thread: hey guys question about the mastercylinder
    vt calais
    Jan 2010
    Default hey guys question about the mastercylinder
    i had a vk 202 drum rear diff
    and i have put the 5.0 ltr injected in and changing the diff to lsd disc brake and i am gonna chang it myself and a mate never done it before so any thing i really need to know would help.,.... also the mastercylinder do i need to change?
    i got a master cylinder out of vl v8 can i just chang that or do i neeed to change the brake booster 2 and any info how to chang master cylinder like oil and bleeding ect cheers sorry i am not that mechanical minded but just wana save on payuing a mechanic cant be 2 hard cheers
    vt calais
    Jan 2010
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by dazz9 View Post
    If your fitting a 1" cyl you will need to change the vac booster. The reason for the bigger Master Cyl is due to bigger piston bores in the calipers your best bet is to use the VE twin spot calipers as the VZ ones have larger bores and will give you poorer pedal feel.
    Scott
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    1" master is a good addition though.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VC
    Oct 2008
    Quote Originally Posted by vkberlina View Post
    Scott
    Why is it necessary to change the booster, I see other people suggesting this but I fitted VT brakes, braided lines, 1" master cylinder and used my VC booster. My car was road tested for compliance and passed with flying colours. I have perfect pedal, no issues at all. I am curious as to the difference.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Every one we have done in the past the 1" master cyl lines up differently on the vac booster and wont physically fit.
    VC
    Oct 2008
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    vt calais
    Jan 2010
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    There is two types of 15/16, drum rear and disc rear. A drum 15/16 cannot be used on a Disc rear end and vice versa. I am not sure if there is any visual differences between the two, differences are all internal.
    vt calais
    Jan 2010
    ok well the guy saids it was out of a v8 vk disc brake rear so should work came wth the booster as well buit mayb i can use the original booster and just change master cylinder over ???????????
    vt calais
    Jan 2010
    VH Vacationer 202, VH SL 185 pack 253
    Feb 2010
    Victoria Pt, Queensland Australia
    MY 81 vh 6cyl rear drum brakes has a 15/16 mastercylinder and my 82 vh 253 rear disc brakes has a 15/16 mastercylinder. As said earlier. The differences must be internal.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Master cylinder are the same, its the booster, single vs double diaphragm. The disc brake boosters have the double diaphragm and is visual bigger in size.
  15. #15
    Feb 2010
    Thanks for clearing up the issues concerning drum to disc mastercylinder v booster.Will look for one. I presume a Vn brakebooster would be ok since they use a 15/16 mastercylinder.
  16. #16
    VS SS, VK 5L Berlina
    Nov 2011
    I want to replace my 15/16" master cylinder with a 1" one. What booster can I use with the 1" master cylinder? Does it need to be double diaphragm booster? Thanks
  17. #17
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    No it will fit either booster but to get the best out of your brakes you need to at least go for the bigger 290mm front discs and calipers...My vh has this with a disc rear and uses a vt style booster/master(because its cheaper to do than the 1 inch) and the brakes are very good with these 290mm discs and calipers on the front.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  18. #18
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    hey mate just letting u know ive just done this to my vh and fitted a vs booster and master cylinder, discs allround. i must admit that this change over is great and pulls up on a dime 110% better than the stock setup. im using 270mm (standard size) slotted rotors allround and fresh sets of pads. i couldnt be happier! but if u wana go the vt m/cylinder & booster and 290mm rotors and callipers to suit it will cost u more, ive never personaly tried out a vt brake system so i cant judge or compare the 2 types. but if your after a cheap improvement run the vs setup with the 270mm rtrs, direct bolt up with no fuss.....oh and u need brakeline adapters!...i sourced mine from pirtek for $5ea all in all it cost me $45 plus half a day of my time. GL
  19. #19
    Nov 2011
    I got a 1" mc and a spare one the other day for really cheap. I will just need to re-kit it, I like the ones with the rectanglular reservoir. I would go the vt brake upgrade but I want to keep the 15" rims. Would the best thing to do, go for the double diaphragm booster and vs calipers?
  20. #20
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by 308Moz View Post
    go the double dphgm booster, 290mm rotors and vs calipers! should/will be able to get the 15's on
  21. #21
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    Quote Originally Posted by dags061 View Post
    Nope, refer to my VB thread.
    I have a vn-vp 1" master i tried... flare is different on the rear pipes couldn't get em to seal, port angle for left side caliper pipe is different.
    You need a vb-vh 1" master. Funny enough so do i... been using the original vb 15/16's one all week so far........
  22. #22
    Nov 2011
    Quote Originally Posted by mr j-man View Post
    Yeah, that sound like a nice combo.
  1. Just a question guys
    By kcpwns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2010, 02:04 PM
  2. Ok Guys, Stupid question of the year.
    By moyboy in forum Car Audio
    Last Post: 24-06-2009, 11:12 PM
  3. Replies: 6
    Last Post: 02-09-2008, 09:53 AM
  4. help guys asap audio question
    By dhesanvs in forum Car Audio
    Last Post: 25-06-2006, 05:17 PM
