Results 1 to 4 of 4
Thread: identifying 202 head
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    Default identifying 202 head
    Hi. Just want to know how do u identify a 202 head. I got a blue motor and the head is different from other blues iv seen. It doesn't have the normal temp switch spot at the back of the head on drivers side and doesn't have the holes on it for the EFE switch and T.V.S. on the manifold side. Also on the other blues iv seen on the side of the head where the spark plugs are there are alot of spots where u can put bolts on to hold stuff on it like fuel flow sensors and stuff. Mine has none of those places for bolts and switches. I found a number on the head if that helps identifying it. Number is 7429477 and D 76 X. It has HOLDEN on it aswel. Cheers
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    A quick google says it's a Red 161 head.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    Quote Originally Posted by Hangman View Post
    Cheers hangman, wot site did u look at and where can I get more info. Is there a reason people would put a 161,173,186 head on a 3.3 202. How do u tell a YT from normal
    Hangman's Avatar
    Jan 2010
    I'd say it's done to up the compression. I just googled the casting number you gave.
  1. Identifying a real VS SS
    By GTP 85 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2011, 03:32 AM
  2. Identifying a VB SL/E
    By Priestley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-06-2010, 10:26 AM
  3. Identifying ECU
    By aussie_macca in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-03-2010, 11:25 AM
  4. Identifying IRS?
    By Kstar. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 10:04 PM
  5. Help Identifying
    By spice_man2069 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2007, 09:04 PM
