Results 1 to 13 of 13
Thread: dieseling 5lt
    vh sle 5lt & vx wagon
    Jan 2011
    victoria
    Default dieseling 5lt
    hey folks i have one for the mechanics out there. just had the quaddy rebuilt on my 5lt and it was going well. i reset the carby to retune it and now i have a motor that is dieseling after turn off and idles really badly. all ignition stuff has been changed and all vacuum lines are hooked up, so stuffed if i know whats happened.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    out of curiosity... what does dieseling mean?
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    Jan 2011
    victoria
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    timing out of whack, carbon build up in the heads.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Anitdieseling solenoid not working correctly, idle solenoid not bring back butterflys past idle setting.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    VH SS
    May 2009
    Toowoomba, Qld
    I'm 99% sure the quadrajet doesn't have an anti-dieseling solenoid, only the varajets.
    but yeah I'd be checking for correct adjustment of the idle solenoid
    VH SL 202
    Feb 2010
    the main butterfly on my carb dosnt evan close it stays open 24/7 lol i look at it and the links on the side that make it open and close are all messed up
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by SL/ENUT View Post
    ^^ this
    or also the float/needle/seat not closing properley or too much fuel pressure (needs 6.5 to 7psi)
    VB SL/E
    Dec 2008
    VX series 2 SS 6 speed,VK Royale 308,VN V6 Ute
    Mar 2009
    Coromandel, NZ
    Jan 2011
    victoria
    thanx guys for all your input. timing is no issue, it turns out that the mixtures were to lean and wrong adjustment on fast idle screw. reset it all last night and hit it tonight and started first crank and kept going which its never done. i normally have to turn the key at least 3 times. got lucky i guess. thanx again for your comments
    VHSLE/VXSS/VXEXEC
    May 2011
    Quote Originally Posted by VK SL 3800 View Post
    .....yep thats what its there for ....also mixture to lean and timing will cause it to run on
    the good thing about getting older....more toysthe bad news more headaches
