Results 1 to 4 of 4
Thread: Convo Pro Fitment
    02' VX Berlina 5.7L
    Feb 2005
    S.E Melb
    Default Convo Pro Fitment
    Hey all,
    Posting for a mate, so bear with me!
    He is building a VK Calais and wants to know about fitting Convo pros.
    Is it possible to fit 15 x 8.5 x 3/8 bs to the rear without tubbing, and over disc brakes? And, would it be better to box the lower control arms to avoid clearance issues?
    Any help would be great!
    He also wants to know diff lengths, etc, for fitting a 9 inch.
    Cheers,
    Sam
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Not sure on the fitment but I have to say that the Convo Pro's will look a million bucks!!!!!
    Anyone that says different has rocks in there head and I can't wait for a few pics, hmmmm donuts ahhhhh!
    vs commo
    Sep 2009
    to fit convo pro's 8.5 3/8th backspace, you must box in trailing arms, shorten diff 70mm each side (or there abouts) and if you want to run disc brakes you have to move the shock mounts to clear the brakes, otherwise run drum brakes. 255 or 10" rear tyres would be the max with stock wheel tubs.
    99 vs maloo hq coupe
    Oct 2011
    brisbane
    also order non multi fit and get a machine shop to drill commodore stud pattern, convos wont fit chev bolt pattern onto commodore, safest way to go!
  1. Convo Pros
    By johnmic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2011, 09:59 PM
  2. WTB: Convo Pro's
    By PEAKN6 in forum Swap / Wanted to Buy / Trade
    Last Post: 13-12-2006, 03:51 AM
  3. Anyone one up for a genreal convo :P?
    By Lukie in forum The Pub
    Last Post: 20-06-2004, 12:29 AM
