Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By Darren_L
  • 1 Post By ari666
Thread: Vk heaters
    Gudgeon's Avatar
    Gudgeon is offline NE1 4SX
    VR Exec S2 and VK 333 Pack Calais
    Jul 2008
    Mount Gambier
    Default Vk heaters
    Can anyone tell me where to find fan resistor block in a vk. Fan motor works and have found some power going into switches... But fan wont work
    There's No Replacement For Displacement
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    an easier check is to make sure the vacuum hose is hooked up to the switch. if no vacuum, then no heater fan. its a weird/strange/retarded/fked up system.
    there are something like 9 vac hoses on a circular... thing. one is vacuum delivery from the engine. need to be full manifold vac.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    I pulled my dash apart to fix the heater
    Allmost all the vacumme likes had fallen off so I was just getting a hissing sound
    Re connected them and wallah now I just get warm air.. Not hot or cold.. Fml
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VH SS
    May 2009
    Toowoomba, Qld
    early Commodore ventilation systems..... gotta love them
    must have been designed by the Irish
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    The resistor block is behind the glovebox on the top of the AC housing near the fan. YOu can see it when the fan is removed, im pretty sure i pulled mine out somehow (theres only 2 screw) without removing anything but it was awhile ago.
    They are a stupid setup, when i bought my car there was a small stick stuck in the fan and it was whipping around in there and busted low speed fan resistor.
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Quote Originally Posted by Darren_L View Post
    so stupid, hq heater - dominates
    vk 10 years newer - shyttttttttttttttt
    ari666's Avatar
    1966 impala
    Mar 2009
    impala wins:
    negative switched (took me a few hours of scratching my head to figure that out) 3 settings: on, slightly on'er and off. 45 years with the same core and same fan and still going strong (kind of)
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Quote Originally Posted by ari666 View Post
    impala wins:
    just more proof that old cars were made to last.
  1. does radiator leak have effect on heaters
    By nashy05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2009, 11:29 AM
  2. vr berlina heaters
    Last Post: 15-03-2009, 08:09 PM
