Results 1 to 7 of 7
Thread: diff I.D.
    VC Commodore
    Mar 2011
    Default diff I.D.
    Hi All
    Im working on my VC tag reads paint: 1d 001-d looks like a canary yellow. Axle gu7 I also have a spare car paint 568-30517 axle gu4 colour is red. Both are standard vc l models. Are the axle codes just a different ratio what are they ? Also what are the colour names for the paint codes? Any info would be helpfull.
    Thanks Dave.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    GU7 is 2.78:1, GU4 3.08:1, thats the ratio's.
    VC Commodore
    Mar 2011
    commodore
    Aug 2009
    australia
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    Not sure if this will help you or not, My VH SS (factory 308, m21, 308.1 LSD) has an axle code of GU4. Funny enough my VB 202 trimatic also has on it's tag an axle code of GU4.
    Looking at a max ellery's book, it doesn't refer to the axle code in the diff section, so i looked at the extra section for LSD diffs, no nothing there...
    Further along it then lists axle codes in a table box listing engine, gearbox and axle combinations to then give you a part number for the tailshaft used in that particular combination.
    If i used the info in the table in the manual, i'll need you to tell me what engine and box combination you're using to let you know what it say's which tailshaft to use with your choice of axle/diff
    my camera is stuffed else i'd take a photo of the page for you.
    Drew
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by drewVHSS View Post
    Drew
    GU4 is the ratio of the Diff regardless of Spinner or LSD
    Scott
    drewVHSS's Avatar
    Apr 2010
    Quote Originally Posted by vkberlina View Post
    Scott
    Thanks mate. Had a feeling that might be the case, but usually if i'm not 100% sure I wont speak up fully.
  1. 304 I need a new diff.. well I want a new diff..and mine's noisy..so..I need a new diff.
    By Warranty Void in forum V8 Development and Modification
    Last Post: 24-05-2010, 02:19 PM
  2. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  3. whats the diff between the diff diffs?(wagon and sedan)
    By redrags in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2009, 09:51 AM
