i know it will be a massive job but has anyone removed a shell from a vk. im thinkin bout removing mine due to the fact that i want to have the chassis all painted and shit. can anyone give me some advice PLEASE.
P.S dont tell me its a waist of time cause its me doing it not you
Have you ever heard of a monocoque chassis ??
If not, Maybe it's time you research it an your VK...
Originally Posted by garth
Its a waste of timeIf you cut the chassis rails off the body it will need to be re engineered and when you weld it back on you will bugger the new paint.
Unlike the HQ series it isnt a separate chassis.
However, I have painted the chassis on a VK before you need to setup an A frame from and rear and basically rotate the car clean it up, mask it up and paint it then mask off the chassis rails when you paint the underside of the body. Pretty straight forward just a big job
Scott
body and chassis is not seperable your best bet is to put the body on a rotiserrie to detail the chassis and underneath.
