Results 1 to 16 of 16
Thread: 1400 kg Trolley Jack
    VH SL/E 5.0
    Nov 2009
    Default 1400 kg Trolley Jack
    Quick question - would a 1400kg trolley jack be ok to lift the front of my car to put some stands under? I'm looking at buying one from Supercheap and there is a huge price difference between the 1400kg and the 2500kg...
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Yeah, more than enough, that's all you need to lift the front/rear of a car.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    spend the extra money and get the 2500 kg jack will pay for itself in the long run
    VH SL/E 5.0
    Nov 2009
    strgas's Avatar
    Oct 2009
    VH SL/E 5.0
    Nov 2009
    Quote Originally Posted by strgas View Post
    Yeah your right and normally I would go for the better one but $27 versus $185 is quite a bit, and I am a little skint at the mo - $27 will get me out of trouble for now..
    Tuned VX SS
    Jun 2010
    im not entirely sure i would trust a $27 jack. to much to lose if it breaks. got me wondering why its so cheap.
    not that a expensive one cant break. age does bad things to tools under those kind of pressures, make sure its looked after to ensure a long life
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Well get the $27 one and just don't put anything more than your arm under there until you have chassis stands under it. As long as the tyres are still on the car, the car can't drop enough for the chassis to pin your arm down so you will still be safe.
    Ronald Reagan (1986)
    commodore
    Aug 2009
    australia
    those cheap trolley jacks are fine for jacking up to put stands under or to change a wheel, but you will find after a while they will leak oil but its just a case of topping it up every now and then through the screw that you turn to lower it if i remember right.
    VH Vacationer 202, VH SL 185 pack 253
    Feb 2010
    Victoria Pt, Queensland Australia
    I bought a 2000kg jack from supercheap and it didnt cost to much more than the 1400kg one. I just jack up the car then put the stands under.Never get under your car if it is only held up with the jack.It may come down on you.
    VH SL/E 5.0
    Nov 2009
    OOOhh yeah the stands will under the car as soon as that jack has done it's job! (lifting the bloody car up!)
    vn
    Nov 2009
    noble park
    the 2500kg jack will lift the car to a better working height if your changing a trans, or wanting to weld up the exhaust.
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    The thing you'll find with the smaller jack is it will be damn hard to jack it up compared to a 2500 jack..
    The amount of leverage is a lot more with the 2500...
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    try some of the trade places I bought my tradequip 2500kg twin piston I think it was from bursons it was only $160-180 It was really cheap, its been great I lifts 2ton of tractor up no worries, my work ute with 1000km in the back twin piston pump makes it really quick up also
    scott
  15. #15
    vyseriesII's Avatar
    vyseriesII is offline The V6 is MACEd
    2004 Vy S Series II
    May 2011
    Unless you planning on supporting the whole weight of the car off the ground a 2500kg isn't really necessary. Especially when used in combo with stands.
  16. #16
    VH SL/E 5.0
    Nov 2009
    At this stage it's just to get it onto stands so I can change the starter motor which has died, fortunately in my garage not in the middle of nowhere! Got to fork out 300 or so bucks for the starter and just can't stretch it to $180 for the 2500kg jack at the mo which would normally be my preference.. Hopefully I won't need to change the tranny or weld up the exhaust anytime soon since they have not long been changed /upgraded .... fingers crossed!
  1. Trolley Jack Suggestions
    By wagon_vs in forum General
    Last Post: 12-07-2011, 08:13 PM
  2. Creaking Trolley Jack
    By levymetal in forum The Pub
    Last Post: 11-01-2010, 06:41 PM
  3. WTB - Trolley Jack
    By AlpineRaven in forum Swap / Wanted to Buy / Trade
    Last Post: 18-05-2006, 07:15 PM
  4. Good Quality Trolley Jack
    By Harvs82 in forum The Pub
    Last Post: 25-03-2006, 04:30 PM
  5. Trolley Jack
    By TigerVX in forum General
    Last Post: 05-12-2005, 03:46 PM
