ive just finished putting my battery in the boot, how do i remove the battery tray ive drilled out the spot welds that i can see, it still wont budge? how many spot welds is there?
It's also welded onto the chassis rail with a vertical bracket
Originally Posted by Reaper:
Originally Posted by Jecs:
yep ive got that one, ive sanded the tray back to try and see them but i cant see any, tryed peeling it back but still held down strong
slide a cold chisel under the bettery tray and give it a hit with a hammer it will show up remaining spot welds to drill out, its not going to be pretty
scott
i just kept bending it up and finding where the spot weld were and grided them out it takes a bit there is shit loads of them.
2002 HSV GTO COUPE
VK calais ls1 turbo conversion (in the build)
2009 turbo v8 landcruiser
My VK http://forums.justcommodores.com.au/...-vk-355-a.html
ok cheers guys will give it another go tomorrow
best way to find the spot welds is to hit it with a blow torch, scorch/burn the paint and hit it with a wire brush, (thats if you are respraying the whole area). Tends to show up the welds nicely then.
