Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Like Tree10Likes
Thread: twin turbo 202?
    VK commodore
    Sep 2011
    Default twin turbo 202?
    for my first car i got a VK with a stock black engine, i wanna make it fast and i want it twin turbo'd
    is this a good idea or am i dreaming? has anyone seen it done and work well?
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Dreaming unless you want to spend around 20x the value of your car on a turbo setup
    VK commodore
    Sep 2011
    even when the car is in mint order, only 100, 000km and manual etc...
    do you get good power etc?
    maybe single turbo instead?
    Rusty's Avatar
    Mar 2010
    Queensland
    Quote Originally Posted by VKorie View Post
    Do a bit of google search for what needs re-inforcing / strengthening and replacing to make it cope with a single turbo let alone two. Cut corners when installing a turbo and you will destroy your car quicker than you realize.
    Power wise - bang for buck would be best off dropping in a V8 and putting a little bit of cash into mods. Still end up thousands cheaper than a TT setup. Thats my opinion - someone may correct me
    VH SL/E 5.0
    Nov 2009
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I disagree.....if I was in ur shoes I'd go turbo just to give it a crack. There's manifolds available but they seem to be worth a bit these days, so make ur own using a set of extractors, few bits of pipe and a flange (I could prolly make a 202 turbo manifold for under $100). Then buy some more pipe to make a dump pipe. Maybe use an EFI intake manifold, run the injection gear, go an aftermarket ECU or even a delco conversion and get the memcal played with. Change to an EFI tank, maybe run an 044 pump, rising rate fuel reg. That's a rough guide.
    If u can do most of it urself, it can be done cheap....but you'll need the tools like a welder and grinder otherwise you'll be paying someone else to do it. If the most work you've done on ur car is give it an oil change and fit a cd player, don't bother. And if it's ur daily driver, again don't bother. It'll be off the road for....days, weeks, months, maybe forever lol, and you'll prolly blow up a motor or 2 trying to get it right. But that's what makes it fun aye!
    VH SL/E 5.0
    Nov 2009
    Better still go for a twin turbo 304. Probably won't cost a whole lot more for much bigger gains.
    DANNY8's Avatar
    Apr 2004
    Will cost a whole lot more when ya blow it up haha. That's the reason I went 253, ya can pick up a runner for $50. Sad thing is my twin turbo 253 dunga that's slapped 2gether and cost around 2-3k has the potential to flog my 12k 308 lol.
    VH SL/E 5.0
    Nov 2009
    Quote Originally Posted by DANNY8 View Post
    you see, I knew the 253 had their uses!
    VK commodore
    Sep 2011
    Dirbatua's Avatar
    Dirbatua is offline Say No to Chev Badges
    VX SS, VR Clubsport
    Apr 2003
    S/e Victoria
    VK 202 black block can only handle a max of 300-350kw (might be rwkw cant remember)before the block cracks and shit goes boom.
    Twin Turbo, single turbo, supercharger, twin superchargers, its all been done before.
    Just be aware it ends up being expensive as all #### in the long run but its something not alot of people have and they are fun to drive.
    Best thing on a VK turbo is to convert it to EFI if it isnt already, makes things alot simpler.
    Take a look at this site and this dudes car.
    Turbo202.com.au - Boosting Holden 6 Enthusiasts!
    Liam's VK Buildup - WTF202 - EFI Turbo 202 VK
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by Dirbatua View Post
    exactly my old blower on my 202 I had once cost more than my efi5l engine and gearbox
    scott
    VH SS
    May 2009
    Toowoomba, Qld
    twin turbo is going to be as dear as poison....
    I realise the twin turbo thing is a dream of yours, but any reason you wouldn't consider just going single turbo ?
    Obviously twin turbos tend to reduce turbo lag, but unless you have a huge budget, the cost is going to blow out big time.
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    as much as i think he is a dreamer
    The only hard part about the twin turbos would be cause of the straight 6 It would definatly not be worth it power wise also
    and with the v8 comments
    Looks like V8s are for poor people the way i read shit all the time Complaining about how much money they dont have to spend on cars.
    Anybody knoes it takes time to save for something so i dont see whats the problem?
  15. #15
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by ToMMMaY View Post
    I prefer to think value for money in an early commodore, V6 & V8 are the best KW for your $$
    LS series may give more power but cost alot more, 202 IMO are a waste of time spending money on I spent about more putting a blower on my EFI 202 than it cost to fit an entire EFI 5L, T5, 3.45 LSD coversion with more power better drivability and better fuel ecomomy and a more reliable setup.
    OP even consider a V6 twin turbo or supercharged V6 setup way better gains to be had over a 202, I would even suggest be outright cheaper, good turn key doner car can be bought cheap and are a great source of disposable engines.
    My Latest project car that I am buying up parts for I have an EFI 5l (low kms) & T5 owing me about $300 after wreaking out the doner car, bolting straight into a a car would see cost going up to $2k total build cost for a pretty quick car. In my books thats bang for buck
    scott
  16. #16
    VH SL/E 5.0
    Nov 2009
    (naturally aspirated) six packs are for P platers....
    Point?
  17. #17
    Jul 2010
    Quote Originally Posted by vkberlina View Post
    scott
    If you could do all the Engine swap yourself Change alot of stuff Grab a bargain of a engine it could be cheaper
    Or instead spend 5-6k for some workshop to do it and still have a stock engine
    5-6k on anyengine will definatly get it going no doubt
  18. #18
    Jul 2010
    Quote Originally Posted by DerekP View Post
    Point?
    Im pretty sure that situation is part of the Law
    Now ontopic
    lets talk about Forced Induction Six packs
    Point?
  19. #19
    VH SL/E 5.0
    Nov 2009
    Now ontopic
    Point?
    Point is, and in the words of ari666 - anything you do to your six banger I can do to my 8 and get a better result.
  20. #20
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    p plater?
    twin turbo?
    or was it first car, and never got rid of it?
    (just comfirming)
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
  21. #21
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    I can see this becoming a bad thread.
    The big picture is, you never see twin turbo'ed 202. Reasons? cause its a dead lose. You do often see the odd turbo'ed Holden 6, not often 202 though to the limit of the block.
  22. #22
    Jul 2010
    Wacking a Gilmer system and thinking your 5l is supercharged does not make it any better my friend.
    So When you do get your ass ripped by a 6cylinder what do you blame it on then
  23. #23
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    No offense but that is in no way relevant to what Derekp said, all he means is if you supercharge your six and he supercharges his 8 he will make more power (maybe not a 253 but you get my point), you then turbo it as well and then he does the same, the 8 makes more power. No matter what you do you the larger displacement will make the most power with the same sort of setup.
  24. #24
    03 VY ss hothouse green
    Jun 2011
    hobart
    there was a bloke down here in tas a while ago that used to drive his lc to the drags run high 11's - low 12's all night and drive home again with a turbo grey 202. stock internals and all he set it all up for about $1800 all he did was put on a blow through carb tap in the oil and home made the piping to his intercooler (which he never even had at first) changed the diff don't know what power he made but he didn't either he didn't care but his time slips talked for them self.
    oh he also cut a hole in his bonnet and glued a paint roller tray upside down with the end cut off for a scoop to get more air in.
    real budget job but it worked a treat.
  25. #25
    VS SS
    Aug 2010
    ACT
    Quote Originally Posted by oscar03 View Post
    Made of awesome.
  1. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 11:38 PM
  2. LS1 single turbo or twin turbo
    By weedo_86 in forum LSx Development and Modification
    Last Post: 05-12-2008, 03:08 PM
  3. 383ci single turbo or twin turbo??
    By adictd in forum V8 Development and Modification
    Last Post: 04-12-2008, 07:49 PM
  4. twin turbo ecotec, turbo selection?
    By jenkos_vl in forum V6 Development And Modification
    Last Post: 08-11-2005, 12:03 PM
