Results 1 to 20 of 20
Thread: ford t5 into vh 308 clutch issues
    Vh sle 5ltr 83
    Mar 2008
    Default ford t5 into vh 308 clutch issues
    hi im currently in the process of putting the ford t5 in my vh and im having issues with the clutch not having enough adjustment with the pressure plate and thrust bearing
    i believe i need a modified pressure plate because my pivot ball is screwed all the way in and the gearbox still has around 20mm before it meets the back off the motor just wondering if anyone has done this conversion and what clutch setup they used im currently using the standard v8 308 setup thanks ben
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    I used xf 6 cyl friction plate, standard holden 308 diaphram plate.
    Throwout fork and bearing was supplied with the bellhousing from dellows as was the spigot bush into the crank.
    All went fine.
    What bellhousing are you using?
    Vh sle 5ltr 83
    Mar 2008
    Vh sle 5ltr 83
    Mar 2008
    how thick is your pressure plate and flywheel do you reckon my pressure plate is around 6cm or 60mm surface to finger and the flywheel not sure but its a just the standard cast one
    Vh sle 5ltr 83
    Mar 2008
    does anyone have an idea? maybe its the spacing with my bellhousing but then i guess it would bottom out in the spigot/crank so im not sure whats going on
    Vh sle 5ltr 83
    Mar 2008
    found out i have to get the fingers on the pressure plate modified 20mm back towards the plate
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    i'm having same problem with a Holden t5 v8 onto a vn 304 in a vl.
    maybe i have to mod my pressure plate also?
    My VL Walkinshaw replica project
    Vh sle 5ltr 83
    Mar 2008
    Yeah got another plate still not right haha not enough throw for reverse but the thrust bearing is pressing on the pressure plate a bit much
    I am here: http://maps.google.com/maps?ll=-37.663959,145.543399
    Jul 2010
    sydney
    i have the same problem farkkkkkkkkkkkkkkkkkkkkk oh well ill try not use reverse lol
    Vh sle 5ltr 83
    Mar 2008
    Jul 2010
    sydney
    vn front half vl rear half.
    yours should be vh rear vn front
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    When I built my VK I made my own tailshaft up using compatible ends, unis etc and welded it up, with careful measurements & planning you can get it spot on, I ran mine un balenced for about a year then finally went to get it balenced and it was within .03 of a gram, the guy actually asked me if it was a factory shaft.
    scott
    Vh sle 5ltr 83
    Mar 2008
    Ahh kk well I have to modify mine at the front section did u gave to do that to yours Scott I have a vn diff and tailshaft in mine I already shortened the rear section when it was still auto and that come up good just gotta do the front section for the t5
    I am here: http://maps.google.com/maps?ll=-37.664320,145.543493
    Jul 2010
    sydney
    Hey bloke dellow conversions in revesby have told me it is defiantly my clutch cable he customs makes them for $100 give em a call might fix your problem also,
    i will let you know how i go with mine.
  15. #15
    Vh sle 5ltr 83
    Mar 2008
    Uwishn a vn manual front section ? Nah I have a full vn tailshaft in mine mate I know I did it myself haha
    I am here: http://maps.google.com/maps?ll=-37.648958,145.535107
  16. #16
    Vh sle 5ltr 83
    Mar 2008
  17. #17
    Jul 2010
    sydney
    not sure ay,i honestly did not try put the whole vn shaft in,i was told to do vn front vl rear.
    wish i did try now would of saved a bit buying a bloody vl v8 shaft lol.
  18. #18
    Vh sle 5ltr 83
    Mar 2008
    Yeah so use a vn manual front section because I no the auto one is way to long and out of a 6 or a 8
    Yeah very keen to see how ur cable goes let me know cause I'll get one and one of there clutch forks as well cause I snapped mine haha
    I am here: http://maps.google.com/maps?ll=-37.648961,145.535034
  19. #19
    Jul 2010
    sydney
    yeah i have a manual vn v8 front,manual vl v8 rear and have no problems.
  20. #20
    Vh sle 5ltr 83
    Mar 2008
    Sweet that sorts out a lot of dramas for me
    What about the slip yoke
  1. T56 in VR clutch issues
    By combatantsomeone in forum General
    Last Post: 04-06-2010, 02:04 PM
  2. New clutch issues
    By deserthead in forum General
    Last Post: 20-01-2010, 02:58 AM
  3. Clutch Bleeding issues
    By the_duke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2009, 10:53 PM
  4. clutch issues
    By lord_davros in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-09-2008, 02:51 PM
  5. Vs Clutch Issues
    By 10wvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2005, 03:03 PM
