Results 1 to 6 of 6
Thread: fuel tank conversion
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Default fuel tank conversion
    so i have recently done a 5.0l conversion to my VH but am still runnin the original fuel tank with an external pump.
    im lookin to convert the tank and increase the holding capacity but want to keep the pump!
    whats the best tank to fit to it for mounting and also filler neck posistion?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Any VB-VS tank will fit, VN-VS you shorten the filler neck slightly (its separate with a hose connecting it to the tank if you didnt know). But any 80l tank from these model will work, VN-VS you could remove the in-tank pump and fit a straight pipe of some sort in its place.
    IMO you are better off going to a VN-VS tank if possible as they are fitted with a swirl pot so you dont have fuel starvation issues when cornering and when low on fuel.
    I have a std VS 63l tank in my car, only mod was the filler neck,still using VK tank straps and using the std VS in-tank pump.
    Unless you bought an expensive external like a 044 or the likes i would also recommend going to an in-tank pump as they are quieter and require no modifications to the pickup.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    there is nothing stopping you running both pumps, I do in my VK a low pressure in tank and an 044 external and it works a treat
    scott
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    yeah iv e got an 044. i have noticed when goin around a corner or up a hill the fuel light tends to flick on when 1/4 tank.
    so the std 6cyl vn-vs tanks are the same sorta dimensions as the vh?
    are there ones that are deeper or sit lower?
    id imagine they would be the v8 ones wouldnt they?
    Scott> are the factory internal pumps already a low pressre pump or do ya have to change it to one?
    thanks guys
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Some V8 carby cars have a low pressure pump and all VN s1 have them, VNs2- VS all should have the single high pressure intank pump.
    You probably want a S1 VN 80l tank, it bolts straight in using the straps from the donor car as they are longer so they wrap around the larger tank. i bought one but be careful as when i pulled out the pickup and level sender i found that the internal rubber return line had broken so no fuel would be sprayed into the swirl pot, which is needed to create a venturi effect to draw any remaining fuel into the swirl pot to keep the pickup submerged.
    vt spac vk calais
    Sep 2011
    cranbourne
    hey guys
    just wondering is a 6cyl pump out of a vs big enough to run an efi 8 or will i need and pump out of a v8?
    cheers Adrian
  1. Replaced standard fuel tank with long range tank..Now car keeps cutting out
    By bj42turbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2011, 09:57 PM
  2. 1998 vs statesman v6, 80l Fuel Tank into VN V6 with standard tank
    Last Post: 19-03-2011, 07:30 PM
  3. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  4. VS conversion to larger fuel tank?
    By alex2_s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2009, 11:10 AM
  5. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
