Results 1 to 6 of 6
Thread: triple manifold for 202.
    VK 202 sedan
    Jun 2010
    Tatura VIC
    Default triple manifold for 202.
    Can you make a triple carb manifold for a 9 port head fit a 12 port head?
    if so what steps would be involved?
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Manifold adapter plate.. probably have to be a custom jobbie..
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    commodore
    Aug 2009
    australia
    VK Executive
    Jul 2008
    I have a 9 port inlet manifold on my twelve port just had to add a couple of small cut outs to line up the manifold studs that dont line up and I die ground the manifold up a bit taller. The exposed vertical edges of the port inlets of the head that are exposed will cause some turbulence as the charge enters the head but still seems to work ok for me. you do have to make sure the manifold is lined up properly so the ports are covered as it is a very close fit.
    VK Turbo build
    My Forum
    Email me
    Anyone can buy one. Its a lot harder to build your own..
    VK 202 sedan
    Jun 2010
    Tatura VIC
    Ah ok, thx for that. Would would be the better manifold to go for a fully open port or the one with the divider?
    Ive added a pic for reference.
    Attached Thumbnails Attached Thumbnails triple manifold for 202.-vxcvxcvxv.jpg
    VK Executive
    Jul 2008
    I would use the one with the divider. If you were stuck using the undivided one maybe bullnose the dividers on the head.
    VK Turbo build
    My Forum
    Email me
  1. Triple LCD Cluster
    By SH.00.MA in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-06-2011, 07:04 PM
  2. Triple su's 300 ono
    By TRICKEDUP in forum Parts And Other Items For Sale
    Last Post: 14-11-2008, 01:23 PM
  3. Triple su carbys for vk
    By scozzman in forum Parts And Other Items For Sale
    Last Post: 17-04-2008, 07:59 PM
  4. Carbs; Triple SU vs Triple 40 DHLA DELLORTO
    By VK6CYL in forum General
    Last Post: 04-02-2008, 11:51 AM
