Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By hiy_po
  • 1 Post By DANNY8
Thread: Vk strating issuses
    1983 vk commodore sl
    Oct 2011
    shellharbour
    Default Vk strating issuses
    brought a vk 202 manual it didnt start when i brought it, the guy who i brought it off said it needed a crank angle sensor after i replaced the sensor and it not starting havent been ####ed to take it to the shop. was wondering if anyone could give me some ideas how to start it. went over starter motor, fuse box, carby n spark plugs all working.
    vh/vk
    Oct 2011
    ummmmm 202's have a crank angle sensor?... check to see if its getting fuel
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    What sensor did you replace? Where was it? 202's don't have a CAS.
    Is it turning over?
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Oct 2011
    shellharbour
    ive checked if the fuel was getting thru, its fine. the sensor i replaced was at the back of the motor near the firewall right at the top of the block. all electrics r working when i try to start it just keeps turning over till the battery dies.
    VH SL/E 5.0
    Nov 2009
    Hangman's Avatar
    Jan 2010
    Trying to think what's up the back of a 202 now haha. Too many drinks for me
    Temp sender is up towards the back of the block from memory. On the red motors anyway.
    I imagine someone will beat me to it, but I'll stick my head in the shed and check one of the 202's I've got here later on if needed. You've lost me with the 202 CAS...
    vh/vk
    Oct 2011
    you may have flodded the engine by now check the firing order, check to see if its sparking, make sure the dizzy is working and on a standard setting
    VK Executive
    Jul 2008
    The OP is correct the EST carb version of the Black 202 does have a CAS and it is as he says at the back of the block. I use the CAS to fire my WOLF3D on my 202 black motor. I would be suspicious of the EST computer being rooted. I would try fitting a HEI dissy and see if it fires using that. I would be surprised if there is not a thread on here somewhere showing how to change the EST dissy to HEI.
    VK Turbo build
    My Forum
    Email me
    Anyone can buy one. Its a lot harder to build your own..
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I'm with hiy_po, chuck in a HEI dizzy and get rid of the EST, that ALWAYS eventually plays up, so chances are it's that!
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    HEI is a plug and play, vacuum signal connects to the EGR valve signal as thats ported vacuum and on a TVS so it only starts to advance when it gets a little temp in it, perfect for dizzy advance, same setup as a VH in the end.
    Oct 2011
    shellharbour
    cheers ill try the the dizzy
    Oct 2011
    shellharbour
    bruh sounds easy enough but fark... do you have to have the engine inline n that cause i ripped that mofo out bruh n sumone told me abou ttiming n the engine being inline, plug n play sounds more simpler then inlining the piston n that ay ... cheers
    Oct 2011
    shellharbour
    if i leave me dizzy outta me engine will i get water in me bottom end, n how the f do i inline me engine for a new dizzy ?????
    Oct 2011
    shellharbour
    cmon an car ele may know this answer is, cmon more detailed then..
    "HEI is a plug and play, vacuum signal connects to the EGR valve signal as thats ported vacuum and on a TVS so it only starts to advance when it gets a little temp in it, perfect for dizzy advance, same setup as a VH in the end." ends up i fked me car pretty much anyone got a blk 202 5 speed for sale?
  15. #15
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    This thread is a hard read
    OP, Have you got a HEI Dizzy?
    What exactly are the symtoms of the engine running rough or not running?
    What exactly have you done to remidy the problem?
    You have to try pretty hard to kill a stock 202 so I think your pretty safe
    Scott
  1. strating probs vp s1
    By craigillz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2005, 07:28 AM
