Results 1 to 6 of 6
Thread: VH 202 stalling
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    Default VH 202 stalling
    Can some1 help. I got a 202 with a lumpy cam (not sure wot cam it is) hydraulic lifters and other head work, nothing ported. Iv got a 350 holley with redline manifold and extractors with 2 or 2 and half inch exhaust. Standard trimatic. I got the car with a rebuilt holley. My problem is, it's hard to start. I gota pump the pedal like crazy and wen it does start, keep idle up at 3000 rpm. Once it's warm it's fine. It idles normally and starts good. But wen I put it in drive it stalls and if I give it a big rev from idle it's got a big flat spot. I'm thinking I need a small shift kit in the trimatic but it could b something more simple whr I dnt have to spend big $ to rectify. Any info would b greatly apreciated.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    I would start by looking at the carby , manual or auto choke set up ? vacum leaks , float level , jet sizes
    VK Executive
    Jul 2008
    accelerator pump??
    VK Turbo build
    My Forum
    Email me
    Anyone can buy one. Its a lot harder to build your own..
    VH SL/E 5.0
    Nov 2009
    Quote Originally Posted by strgas View Post
    Agree, sounds like a carby issue to me. I'd be focusing on mixture, float and vacuum leaks.
    VH Vacationer 202, VH SL 185 pack 253
    Feb 2010
    Victoria Pt, Queensland Australia
    Mate I have had mega probs with my holley. Stock 202 ,headers, 2 1/4 exhaust, standard manifold with 350 holley. If you are running a redline manifold it could be leaking as it suits a red and not blue 202. I ditched the auto for an M20 and its the best thing I ever did.I have small jets and found that if the accelerator pump isnt adjusted right it wont start easy. Timing was also an issue and after a lot of adjusting finally got it right.I run power steering as well as AC and is hard to see the timing mark. Give the holley a kit and yes float levels play a big part. Is the choke manual or automatic. Mine is automatic and when hot the spring opens it wide open. Good luck.
    VHSLE/VXSS/VXEXEC
    May 2011
    sounds like carby to me no auto choke or its not working
    the good thing about getting older....more toysthe bad news more headaches
  1. stalling
    By commodore1todd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2010, 11:12 PM
  2. VL stalling
    By shannon78 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-04-2010, 01:29 AM
  3. stalling but not...
    By vx_ss_black in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2008, 08:49 PM
  4. Why is VN Stalling???
    By blackduck11 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2006, 03:00 AM
  5. Stalling
    By VLtuff in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-02-2006, 01:06 PM
