Results 1 to 5 of 5
Thread: Which wires to take out for EST to HEI conversion???
    VK commodore
    Apr 2011
    Cool Which wires to take out for EST to HEI conversion???
    Hi peoples i am about to do a EST to HEI conversion on my son,s VK commodore, and would like to rip out the EST completely!Can someone direct me to the step by step link for this procedure or explain what i need to remove,as i want to completely remove it as it should have been done so by holdel, better still they should'nt have made it in the first place as it's a peice of crap!lol
    At a guess i follow all the wires to where they go and just rip it out??? Your help is much appreciated.
    VK Executive
    Jul 2008
    Just take the Black wire off the negative side of the coil and the EST is disconnected. Remove the est dizzy drop in the HEI one wire it up to the coil and your away.
    Only thing I dont really remember is if there is an ignition power source, but if not just add it to +ve side of coil
    VK Turbo build
    My Forum
    Email me
    Anyone can buy one. Its a lot harder to build your own..
    VK commodore
    Apr 2011
    Thanks for the help and i understand how to get the dizzy working,but i want to remove the whole EST unit as well and throw it in the bin lol any help on that would be great. Cheers
    VK Executive
    Jul 2008
    once the coil is no longer being fired by the EST you can unplug it and throw it in the bin
    VK Turbo build
    My Forum
    Email me
    85 VK SL - 79 VB 253
    Jun 2009
    NSW
    EST has these inputs-
    Throttle position switch - on carb - little micro switch.
    Vacuum pressure - vac hose going to a Bosch unit near fuse box - converts the vac signal to electrical current.
    Crank angle/position sensor - on rear of motor - unplug the connection and tie up out of the way.
    Separate Temp sensor - located in thermostat housing-that thing you get snagged on all the time- blue plug, I think.
    Been over 18 months since I removed mine, some info is a bit hazy.
    ECU is located in PS kick panel - disconnect battery, unplug loom, bin it.
    I hid all my leftover engine bay loom behind the fuse box.
  1. VT v6 conversion issues... wires don't like me
    By hdt_sle05 in forum Electrical Wiring / Questions
    Last Post: 22-05-2012, 07:25 PM
  2. VR BUICK COIL PACK WIRES + and - which wires???
    By H1GHROLLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2010, 09:32 PM
  3. Where to run the wires for a amp and sub in a vs?
    By vs_commy5506 in forum Car Audio
    Last Post: 25-07-2009, 06:23 PM
  4. where to run the wires
    By Fun_Bucket in forum Car Audio
    Last Post: 06-07-2009, 11:09 PM
  5. Amp Wires?
    By todds_vt_2005 in forum Car Audio
    Last Post: 19-03-2006, 11:46 PM
