Results 1 to 2 of 2
Thread: VH SLE ignition switch wiring
    VH SL/E 3.3
    Jan 2011
    BROOKDALE W.A
    Default VH SLE ignition switch wiring
    Hi there. Could some1 put a pic of the VH SLE wiring that goes into the ignition switch. I bought the car and a couple of the wires have been cut and joined. I looked at a VH wagon and it had 1 different colour going into it. Just Wana c if there is a difference from standard sl/slx to the SLE. Pics would b helpful thanks.
    weston is offline Holden VH V6 Commodore
    VH Commodore
    Apr 2009
    Hey mate not sure if it helps but in the gregorys book i got there are six wires as follows
    1/ Pink - runs to the fuse box Fuses for light switch feed, 2 x ignition switch feeds (also branches of to the)
    2/ Pink - runs to coil also joins into the first pink wire
    3/ Violet - run to neutral safety switch, starter solenoid
    4/ Tan - runs to brake fail switch
    5/ Red - runs to fusible link and to fuse box top for fuses LHS
    6/ Brown - runs to top of the lower seven fuses i the fuse box and Flasher relay
    Hope this is of some help mate cheers
  1. Ignition switch
    By Buggy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2009, 03:36 PM
  2. ignition switch
    By 6-PAC-ATTACK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-03-2009, 08:09 PM
  3. Starter motor/ignition switch/neutral safety switch?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2009, 08:19 PM
  4. ignition switch
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-07-2006, 11:23 PM
  5. HELP! VK Ignition Switch
    By CommodoreChick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-11-2005, 07:10 PM
