Results 1 to 3 of 3
Thread: Help efi tank problem!
    VH SL 202
    Feb 2010
    Default Help efi tank problem!
    hey guys i now have a 80L tank for my vh and was just wondering on how im gonna go about wiring up the fuel pump and running it on a carby motor.. im guessing ill need a fuel pressure regulator. The fuel pump/tank is out of a vn V8 i did use the search option but didnt find much that helps
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Lol, I have this exact problem, 80L tank sitting there ready to go into a carbie fed V8.
    What I was going to try as its a high pressure pump is one of 2 things
    1 - give it a try disconnected return blocked off it may pass fuel through turned off and the mechanical pump sill will work
    2- make a new sender (gut the old one) and fit a low pressure electric pump instead, or just have a straight through pipe
    I just have bigger projects to worry about atm
    scott
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I would buy a new internal low pressure pump to replace the existing one (just so u know it's good), then run an external electric pump with a regulator. Don't use the EFI pump, that'll push shitloads of juice and like 95% of it will have to go thru a return and back to the tank.
    Run an external pump like this.
    Carter Universal Electric Fuel Pump 100GPH 6-8PSI P4600 | eBay
    Along with a regulator like this.
    UNIVERSAL FUEL PRESSURE REGULATOR 4.5-9 HOLLEY 12-803 | eBay
    Or a pump and reg package like this.
    Holley Blue Electric Fuel Pumps # 12-802 | eBay
    Or just use a cheap facet style pump like this (still use the regulator above).
    http://www.ebay.com.au/itm/4-0-6-0ps...ht_1098wt_1185
    I used one of those facet style pumps on me 308 wagz. It was ok for general driving, but when it hit 5-6000rpm it couldn't keep up. The one in the link I rekon is the next size up from wat I had I rekon, so it should be fine for ur 202. Just run one of those with the regulator and see how ya go. If u use an EFI pump ur gonna have to run a return line back to the tank. Carby motors need about 6-7psi and EFI motors are up around 45-50psi I think.
  1. Fuel tank capacity problem
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2011, 04:17 PM
  2. VN SS tank problem
    By VK SL 3800 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2011, 10:12 PM
  3. Strange fuel related, half tank, right corner problem.
    By adomatt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2009, 07:51 PM
  4. [NSW] F/S overflow tank,surge tank ,breather tank
    By vpcalais6 in forum Parts And Other Items For Sale
    Last Post: 17-07-2009, 08:09 PM
  5. problem with fuel pump or tank
    By SaGe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2006, 02:19 PM
