Hey guys,
I'm new to this site but from what i have seen this site has people that actually know what their talking about.
Anyway, i have a Carby fed 202 in my VK and im have a lot of problems with the carby / Vac system. i was just wondering what to do and where to go.
Basically a couple of weeks ago i went to go for a drive in my car and every time i accelerated the car hopped. So when i got home i pulled the carby out to check it out and clean it being a varajet. i pulled it apart and put new jets and gaskets in it. while i had it off i decided to check the EGR Valve and EGR Valve Adapter. When i pulled both out they where a mess. The adapter was blocked and the Valve didnt work. The whole top part of both had been filled up with a glue or bog. the adapter had a pretty big chunk out of it up the top (probably why the person before me glued it up). I then saw that the inlet manifold had glue in it to. So i replaced the inlet manifold and the EGR valve and adapter. i cleaned it all out and put them back in. i was then putting the carby in and i cracked one of the mounts on the bottom. luckily i had another carby, so i put that on. after putting all the system back together, i went to run it. unfortunately for me in ran like crap. first thing i did was jump on the net to check if i could get any diagrams on the carby / vac system. i found one at VK Berlina Project ... my car is missing quite a few components that are ment to be there so i am now stuck with the vac system, carby and dizzy ( it has a vac hose off it that wasnt on the diagram).
i need all the help i can get
Thanks Brandon![]()
how do i add more photos or delete the old ones ?
got em....![]()
i through my varyshit carb out and put a weber carb on
Just connect it up as per the diagrams on my site, if some of the ported vac switches are broken replace them.
Scott
im also missing parts from that diagram like the air pump diverter valve and the exhaust heat valve actuator...
