Hey all
Im getting one, but im not sure which size is best
VK 202 carby.
Thanks![]()
DaZ
Project: Shifty1 commences Feb 2007
The_Monk says:
im a leech
Depends what has been done to the engine
On a hot 202 a 2 1/2" from the extractors back should be a good size on a mild or stocker I would go a 2" from the extractors back.
Get the joins in the exhaust flanged rather than press fit with clamps, better to work on, less chance of leaking.
I would go a single muffler at the front with a hotdog at the rear.
It you get a piece of stainless at the size you want polish it up and get them to weld it on the end of the pipe for an exhaust tip, it will never rust and look better than a chrome tip.
cheers
Scott
cheers
Scott
Engine is fully stock, ill look into a 2 inch. Also, ive heard you can get away with having only one muffler.. whats that do? Is it bad?
DaZ
The_Monk says:
im a leech
It wouldnt be bad, you could depending on the engine get away with it. I would give it a go if its a little loud get a hotdog put on.
cheers
Scott
hotdog? hahahaha![]()
id say go 2 1/4 inch exhaust.for a tougher note id get a barrel type muffler and put it right at the back with no muffler under the car.if it is for some reason to loud u can put a hotdog etc where the normal muffler will be
having the exhaust exiting straight from the muffler with no piping after it gives a tougher thump to the exhaust note
So some people are complaining about my motto on cops.well if u knew what ive been thru u wouldnt.so quit your whinging!
i hate cops!
ditto go the 2 1/4" for a worked motor or 2" for a stocker, any bigger and 202s lose power
ok, i got the 2. Sounds n goes great
Thanks guys![]()
DaZ
The_Monk says:
im a leech
a bit late now
i've got a fairly small exhaust, but it does have a single muffler before the diff and extractors. it gives it a nice note, without being too excessive. even dad thinks it sounds nice.
ECOTEC KICKED IN yO!!!!!!
What size is it mate/
DaZ
The_Monk says:
im a leech
1 3/4 i think . it is pretty small. i think it might even be the standard size.
Ah okay, it would be least sus to cops at leastOriginally Posted by vh-holden
DaZ
The_Monk says:
im a leech
yep, but it is enough to keep me happy and is distinct enough that people recognise my car comingOriginally Posted by vk-8t5
Im payin $650 for Luckey headers with a luckey 2 1/2 zorst with a single muffler underneeth the car.
Also i hear Luckey arnt makin headers anymore, currently they are the cheapest headers for a 202 at bout 250 a piece.
extractors 2 inch pipe single muffler in the middle and hotdog at the back it is legal and sounds nice, like a v8 on idle, if u want a good sounding cheap exhaust go with that setup but it up 2 personal opinion .
vks
