Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Like Tree5Likes
Thread: ls2 into 1979 vb commodore
    vb sl
    Jun 2010
    Bajool QLD
    Default ls2 into 1979 vb commodore
    hey im new to posting stuff but here goes
    ive just recently finished fitting (squeezing) an ls2 gen 4 from a vz into my vb
    backed up by a T400 auto and a ford nine inch with a detroit tru track centre
    with 3.7 gears i had to drop the power steering rack down flush with the k frame for clearance
    issues after that i used extractors and a starter motor converter from c.a.e automotive
    all seemed to fit in without to much hasles great challenge to overcome and glad to be
    driving it
    VR Calais
    Mar 2011
    Plumpton
    Very interested in seeing pics mate sounds good to me
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    VK Wagon
    Oct 2010
    geelong, VIC
    pics pics pics....my mate is about to start putting an ls2 into his VB as well, and later down the track i'll be doing it to my wagon...you guna run it down the track?
    vb sl
    Jun 2010
    Bajool QLD
    i keep trying to put my pictures up but it keeps saying they are too large?? help please
    yes im going to race it but its also my daily driver just getting it rewired at the moment
    vb sl
    Jun 2010
    Bajool QLD
    vb sl
    Jun 2010
    Bajool QLD
    vb sl
    Jun 2010
    Bajool QLD
    vb sl
    Jun 2010
    Bajool QLD
    vb sl
    Jun 2010
    Bajool QLD
    vb sl
    Jun 2010
    Bajool QLD
    vb sl
    Jun 2010
    Bajool QLD
    vb sl
    Jun 2010
    Bajool QLD
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    Sweeeeeettt
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
  15. #15
    vb sl
    Jun 2010
    Bajool QLD
    thanks
    glad its all done just getting rewired and hopefully all sweet then
  16. #16
    vr ss / vh
    Jun 2011
    perth
    hey mate awsome to see some pics of this conversion done finally as im just getting ready now to put my ls1 motor and l460e out of a vx into my vh i just had a couple of questions for you hope you dont mind and im not expecting you to answer them if you dont want to but i was wondering about the radiator and the bracket it looks like you have fabricated what radiator did you use was my first question and i was also curious about what you said about dropping the power steering rack down flush with the k frame i was under the impression that useing a vn/r/s v8 k frame and steering rack with the vl intermediate shaft would solve any issuse there is with clearance..is that not true or did you use a different k frame and steering rack??
  17. #17
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    Quote Originally Posted by gen3_vh View Post
    I know I'm being a bit of a grammar nazi here but can you please incorporate full stops and paragraphs it your posts. You have asked some good questions but it is deadset painful to read. I had to go over it several times to figure out what you are saying. I did a quick edit of your post (below) which took all of thirty seconds and is way easier to read.
    Hey mate, awesome to see some pics of this conversion done finally as I'm just getting ready now to put my ls1 motor and l460e out of a vx into my vh. I just had a couple of questions for you, I hope you dont mind and I'm not expecting you to answer them if you dont want to.
    I was wondering about the radiator and the bracket it looks like you have fabricated. What radiator did you use?
    I was also curious about what you said about dropping the power steering rack down flush with the k frame. I was under the impression that using a vn/r/s v8 k frame and steering rack with the vl intermediate shaft would solve any issuse there is with clearance, is that true or did you use a different k frame and steering rack?
    My Garage:
    VZ SS 6ltr 6 speed silver
    VN 5ltr 5 speed Gold (Ex NSWPF Highway Patrol)
    VH EFI 5ltr Supra 5 speed tiger mica
    XC Barina SRI 1.8ltr 5 speed silver
  18. #18
    vr ss / vh
    Jun 2011
    perth
    Cheers for the edit there does look a bit better im no grammar expert nor would i want to be...im gessing you dont have any answers for the questions i asked ??
    Quote Originally Posted by tigervh View Post
  19. #19
    Sep 2005
    Newcastle
    Sorry mate, the only conversion I've done is an injected 5 litre and Supra 5 speed into a VH, appart from a few things that's a straight bolt in.
    I'm not a grammar expert either, just a tradie. Chucking in a few capitals, commas and fullstops aint that difficult!
    My Garage:
  20. #20
    vb sl
    Jun 2010
    Bajool QLD
    Hey bud
    I don't mind answer at all I bought the radiator from a place in Victoria off eBay just look up vb/vc/vh radiator, as for the mounts I chose to remove the old ones due to cracking and also I could mount my tranny cooler of it
    I moved the power steering rack to fit my extractors past the power steer rack on the drivers side, I never thought to go later model k-frame but after you mentioning it I may look into it. I never used the 4L60E tranny that was standard with my engine, I thought they were to long and wide for the transmission tunnel and for where the cross member mount. I hope that helps ya mate
  21. #21
    Vk ls1 turbo
    Aug 2009
    townsville
    hey mate what convertor did you use with your turbo 400 is it a th400 convertor or is it a custom one. what flex plate you using.
    2002 HSV GTO COUPE
    VK calais ls1 turbo conversion (in the build)
    2009 turbo v8 landcruiser
    My VK http://forums.justcommodores.com.au/...-vk-355-a.html
  22. #22
    vr ss / vh
    Jun 2011
    perth
    Hey good idea with the mount for the radiator and trans cooler might put it to use myself...
    the k frame question was a good piece of mind for me as ive just gone out and bought the vn k frame steering rack and vl shaft and after reading what you posted and having already fitted your motor thought i may have wasted my money...which would have sucked as i one of the guys on here posted that pacemaker are doing extractors for the conversion and should be done in a week or two and would rather have a set of them hanging off the ls1 than parts i cant use...
    Yeah im going to fit the original box as i have it and will save me a few bucks instead of going out and getting a whole new t400 i was having a look around yesterday and cae do a crossmember for the conversion but still cant get a definant answer off any one on if it fits in with out any cutting/mods ect
    Quote Originally Posted by sweetvb View Post
    Hey bud
  23. #23
    vb sl
    Jun 2010
    Bajool QLD
    RE: OFFT4P
    i used a 3000 rpm stall convertor and an aftermarket flex plate i had to space my flex plate for the left hand starter convertor
    RE:gen3_vh
    yea i used a set of extractors from cae automotive wich they said would be a bolt in fit but i had to move my power sterring rack for more clearance
    so i never bought there crossmember form them i just made my own up all the other bits i bought from them where spot on and easy to deal with, just by looking at the standard gear box i thought they wouldnt fit so i cant help ya there
  24. #24
    1979sle commodore
    Feb 2012
    auckland.nz
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    This would be a dream conversion for me..
    I'm curious to the total build cost?
    Current project; VH SL/X known as "NFNSUS"
    Ready for a overhaul due to licence issues
  1. Chrisso's 1979 VB commodore!!!!!!!!!!
    By chrisso 82 in forum VB - VC - VH - VK
    Last Post: 24-03-2012, 07:06 AM
  2. [SA] 1979 Holden VB Commodore SL 308 4 Speed
    By RazzaCaine in forum Vehicles For Sale
    Last Post: 25-06-2011, 09:57 AM
  3. 1979 VB Commodore Stolen Toukley NSW 12:20AM 27/2
    By BradZ in forum VB - VC - VH - VK
    Last Post: 01-03-2009, 08:07 PM
