Results 1 to 5 of 5
Thread: blowing smoke under power
    VK executive
    Dec 2009
    Brisbane, Caboolture
    Default blowing smoke under power
    Hey guys
    my vk seems to blow smoke when i put my foot down a little its a 202 motor and i think its on its way out my mechanic said 1 of my cylinders is not fully working properly
    its white smoke, not sure if it has some blue in it, but i was wondering is it blue smoke or black smoke that is bad? and what would be the cause its a carby motor and i've had the carby redone with a kit and chemical cleaned ect not to long ago
    any advice be great thanks
    VE International 3.6L
    Jun 2011
    Gold Coast.
    White smoke is water, blue smoke is oil, and black smoke is fuel.
    White smoke. Is it using coolant? i.e. Are you often topping up the radiator?
    Blue smoke. Is it using oil? i.e. Are you topping the oil up often? What oil are you using?
    Black smoke. Are you using more fuel than usual? Have you changed the air filter often? When did you last put a new set of plugs into it?
    How many kilometers? If high, could just be worn out and a change over engine or re-build might be needed to fix it.
    VS Calais & vh sl
    Dec 2006
    deception bay
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    VK executive
    Dec 2009
    it does go through the fuel and it does use a fair bit of oil, but it doesn't blow black smoke just whitish/blue can't really notice the blue to much tho
    and the oil i use is shell helix 20w50 only recently did a oil change, i know i need to change petrol filter and it does leak oil not sure where, and it is a old motor say 250+k's i reckon it is up for a recon motor i would say
    can get a done up 202 for $1000 then have to either install it myself or pay the mechanic who looks after my car,
    not sure weather to get the 202, v6 or a v8 don't have much money atm cause of xmas ect, but hopefully in the new year i'll have a bit more and will decide then i guess
    thanks for the information
  1. blowing smoke...using oil..
    By thewaxpigg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2010, 02:33 AM
  2. blowing smoke
    By mark&sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2007, 06:18 PM
  3. Blowing Smoke
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2007, 01:35 AM
  4. vs blowing smoke
    By lexcedore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2006, 11:08 AM
  5. Blowing smoke
    By minimefx in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-07-2006, 09:00 AM
