has anyone on here wired up a speedway engine to fun of a racing push button start panel ive never done this b4 do i need my original v8 engine wireing harness to wire it up so start and drive the engine as i dont wanna make any mistakes removing any wireing i need maybe a diagrame if anyone has one
its pretty easy its essectively a hotwiring setup
You running electric or mechanical fuel pump?
Carb or EFI?
you need a 12V+ve source then up to ignition switch to power the coil, fuel pump if electric, then a push button switch to the starter motor
scott
carby 253 with a elec fuel pump
