Hi there. i got a blue 202 with a 161 head on it. I was trying to take the square headed bolt out whr the temp switch goes in near the back of the head on carby side to put a temp switch in which i didnt have. That is the only place on a 161 head u can put a temp switch. I snapped the bolt. I drilled a small hole to use a easy out but now iv snapped that too. Any ideas on wot else i can do. It now leaks water from there.
Maybe drill it out again, start small and work ur way up, then when it's big enuf, retap it. That would work I rekon. Or weld sumfin on the top of the bolt which u can use to undo it, maybe a socket. Then while it's still glowing red, try and undo it then.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
if you heat it up red hot then mig it up it will seal, if you want to try again use a carbide burr on a die grinder to drill out the tap or easy out.
If you want to put the sensor in your best be will be to call a thread repair guy to put a brass insert in it.
scott
easy-out snapped inside = forget about drilling it. itll just eat every drillbit you touch it with.
you could try a plumbers wrench. always worked well for me in the past.
Drilling with a normal drill bit yes, doing up my backhoe I have had to weld up drill and retap heaps of threads, so far snapped 6 taps and 2 easy outs (not so easy).
If the end of the broken drill/tap/easy out is at the end of the hole you can sit a washer over it and mig the centre of the washer tot he bit, then weld a nut to the washer and then remove the stuck bit.
Else a rounded toped carbide burr will eat an easy out, tap etc for breakfast
Else you can try cracking it with a centre punch, cold chisel etc and chip it out.
Else you can heat the bit up and it will drill out easier also.
cheers
Scott
