Results 1 to 4 of 4
Thread: imperial / metric
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    Default imperial / metric
    I've just finished putting in my new carpet but.. The LAST screw I need to put in, has rooted itself.
    I'm not sure what it's called so please excuse the following;
    Is the hole which the seat belt holder/clip thingy goes it, metric or imperial thread?
    I did a google and it said Holden switched from imperial to fully metric but I couldn't find what model they switched at. Thanks.
    Current project; VH SL/X known as "NFNSUS"
    Ready for a overhaul due to licence issues
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Pretty sure it would have been metric by then
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VY SS
    May 2011
    Auckland
    Take out one of the others that aren't rooted and go down to a bolt supplier.
    Otherwise measure the diameter of the bolt to the top of the peaks (this will be slightly less than nominal)
    Then if it's metric you measure the pitch by the distance between the threads along the bolt. If its imperial by the threads per inch. There are multiple pitches available at a diameter and you need the right one, or it'll strip the bolt or hole straight away.
    I wouldn't be so sure it's metric, the bolt on the floor in the back of my vs wagon was imperial. I got a longer one to hold my sub box down.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    More than likely be 7/16" UNF, just check it threads in easily (with your fingers) before you put a tool on it
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
  1. Replies: 12
    Last Post: 05-05-2011, 08:57 AM
  2. Dumb question.. Are VK brake/fuel lines metric or imperial?
    By Staggie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-05-2010, 11:10 PM
  3. Metric or Imperial?
    By slobberingant in forum General
    Last Post: 03-12-2009, 09:36 PM
  4. [SA] Blue Point / Snap On Ratchet Spanners Metric & Imperial
    By Vr929 in forum Parts And Other Items For Sale
    Last Post: 05-07-2009, 09:57 PM
  5. HP - KW KW - HP Metric and imperial
    By Pretender in forum General
    Last Post: 06-02-2006, 01:47 AM
