Results 1 to 10 of 10
Thread: turbo 400 gear box wont change where does vacuum hose go? HELP ASAP
    budgieVH's Avatar
    budgieVH is offline get in shut up nd hang on
    Injected 5ltr VH SL/E-VH Blue 202-GQ Nissan Patrol
    May 2009
    Australia
    Default turbo 400 gear box wont change where does vacuum hose go? HELP ASAP
    hey guys was just fixing my speedo cable got that done..
    Took for a drive works but now it wont change gear there is a vacuum hose on the side of the box just hanging there
    so i must have pumped it and its fallen off..
    no idea where it goes?
    where does the other end connect????
    need to know asap other wise cant drive home
    cheers budgie!
    Budgies Car Sound
    Facebook www.facebook.com/budgiescarsound
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    vacuum tree on the manifold, near the dizzy. This is a V8 right?
    budgieVH's Avatar
    May 2009
    Australia
    Quote Originally Posted by SL/ENUT View Post
    yes its a 5ltr from a VS
    stallie, quick shift..
    hmm okay the hose is like 300mm long though unless there is an extension?
    Budgies Car Sound
    hj kingswood
    Sep 2011
    Melton
    Sl/enut us right, it goes to the vacuum tree on back of the inlet just infront of the dizzy on the old stuff. Not sure about vs though check where your Bataks vacuum hose goes to, might give you an idea, as for being so short, check the floor, under the flood and infront of the firewall, the othe end has to be there some where, I've got trimatic and it's also short, runs to a solid line much the same as a brake line
    budgieVH's Avatar
    May 2009
    Australia
    i cant figure it out there was a hose on top of the gear box aswell i connected it to that nothing there so it must not go there. cant find any thing argh!! been looking for hours..
    Budgies Car Sound
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    Just get a vaccum source from the motor. I don't think it matters to much where from
    540rwhp Turbo LS1. Mmm skids
    Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
    Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Most likely the breather, originally runs into the drivers side chassis rail so you dont see the oil that comes out when working hard.
    budgieVH's Avatar
    May 2009
    Australia
    Quote Originally Posted by VK SL 3800 View Post
    if thats the case then why wont it change?
    Budgies Car Sound
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    budgieVH's Avatar
    May 2009
    Australia
    okay guys finnaly found where it went i did alot of research to try and find pictures.. where the brake booster hose is i followed that to the manifold and underneath i could feel a little nipple so i plugged it back into that and took it for another drive!
    problem fixed thanks guys!
    Budgies Car Sound
  1. my auto wont change gear
    By HuskeyVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2011, 08:56 PM
  2. VR vacuum hose loose/vacuum canister missing?
    By Pickled in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2010, 10:05 AM
  3. Vn auto wont change out of 1st gear
    By Cameron in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2008, 11:35 AM
  4. VH 253 auto wont change out of 1st gear
    By jimmyd17 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-12-2005, 09:33 PM
  5. Changed my trans fluid finnaly, now car wont change gear sometimes.
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2005, 08:59 PM
